spikedog
How to diagnose No space left on device error
Sat Jan 02, 2016 10:22 pm
I'm new to Linux and I've just set up a Raspberry Pi 2 with Raspbian Jessie.
The device runs fine for about a day then I start getting errors "No space left on device". I can't find which device is causing the problem and the errors come with a number of commands. A reboot fixes the problem for a while.
I've had this problem wile installing Apache and PHP using sudo apt-get and I often get it while starting and stopping services. This is my most recent error
pi@pi1:~ $ sudo systemctl restart apache2.service
Error: No space left on device
pi@pi1:~ $ sudo service apache2 restart
pi@pi1:~ $ sudo /etc/init.d/apache2 restart
[....] Restarting apache2 (via systemctl): apache2.serviceError: No space left on device
. ok
The problem isn't just with Apache2. I'm getting this with all services.
As far as I can tell I have space left on all devices
pi@pi1:~ $ df -hl
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  3.8G  9.7G  29% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M   13M  451M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p1   60M   20M   41M  33% /boot
/dev/sda1        29G  7.7G   19G  29% /data0
tmpfs            93M     0   93M   0% /run/user/1000
pi@pi1:~ $ df -hil
Filesystem     Inodes IUsed IFree IUse% Mounted on
/dev/root        923K  177K  747K   20% /
devtmpfs         115K   354  115K    1% /dev
tmpfs            116K     1  116K    1% /dev/shm
tmpfs            116K   548  116K    1% /run
tmpfs            116K     6  116K    1% /run/lock
tmpfs            116K    10  116K    1% /sys/fs/cgroup
/dev/mmcblk0p1      0     0     0     - /boot
/dev/sda1        1.8M   95K  1.8M    6% /data0
tmpfs            116K     5  116K    1% /run/user/1000
Any ideas how I can get more information on what is causing the error?
QuietZone
Re: How to diagnose No space left on device error
Sat Jan 02, 2016 10:31 pm
This is usually caused by the combination of two erroneous actions:
1) Installing Raspbian from a "raw image" instead of from NOOBS.
2) Failing to "expand the rootfs" (using "raspi-config")
"If you haven't got anything nice to say about anybody come sit next to me." — Alice Roosevelt Longworth
kusti8
Sat Jan 02, 2016 10:32 pm
QuietZone wrote:This is usually caused by the combination of two erroneous actions:
As shown in the df output the OP has done so.
There are 10 types of people: those who understand binary and those who don't.
spikedog
Sun Jan 03, 2016 1:49 am
Thanks for the replies.
I have found the problem now and it isn't obvious from the error message.
I have enough physical space and already run raspi-config to use all available space.
The problem only occurs when using systemctl (either directly or during installation, reboot etc) and is caused by the max_user_watches limit. The default value of 8192 might be enough for most but I'm also running crashplan and the watch limit is being exhausted. This wasn't a problem on my previous installation using Wheezy, probably due to the introduction of systemd in Jessie.
My solution is to add
fs.inotify.max_user_watches=1048576
to /etc/sysctl.conf and the problem hasn't come back. I'll keep watching in case other problems arise.
manderso
Thu Mar 31, 2016 9:02 am
spikedog wrote:Thanks for the replies.
This was my problem exactly. I'm running Crashplan on my pi 3 and am trying to install the lets encrypt client, which kept bombing at the nginx installation. Your solution did the trick. How'd you find it?
manderso
Thu Mar 31, 2016 10:23 pm
This page has more information on how this is happening:
http://unix.stackexchange.com/questions ... it-reached
govindg279
Sat Jul 16, 2016 4:58 pm
I got the same error, but in my case the the root file system is 100% and raspi-config also failed.
pi@raspberrypi:~ $ df -hl
/dev/root 3.6G 3.6G 0 100% /
tmpfs 463M 6.3M 457M 2% /run
/dev/mmcblk0p1 60M 20M 41M 34% /boot
The below command worked for me:
sudo resize2fs /dev/mmcblk0p2
Sat Jul 16, 2016 7:04 pm
That 4GB SDCard isn't big enough for regular Raspbian Jessie. You can fit Jessie-lite on a 4GB card, but for regular Jessie you need at least 8GB.
