mitnk
sudo extends ~ to /root
Sat Jan 02, 2016 5:00 pm
Hi everyone,
I am write some bash code like this:
echo ${XYZ:-~/.vimrc}
saved as foo.sh and I run it with:
sudo ./foo.sh
When I run at Raspbian, I got:
/root/.vimrc
(What I expected was: /home/pi/.vimrc)
But at other OS (Ubuntu and OS X), I got this (mitnk is my username):
/home/mitnk/.vimrc
The OS info:
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
Can anyone explain why it's not `/home/pi/.vimrc`? Thanks.
disorientedp
Re: sudo extends ~ to /root
Sun Jan 03, 2016 12:51 am
Try ~pi/otherstuff instead of ~/otherstuff.
disorientedp
Sun Jan 03, 2016 12:53 am
The root home directory (which is what commands are run through with sudo) is different than other home directories.
QuietZone
Sun Jan 03, 2016 2:27 am
The real answer to this question is that it is, as you've observed, kind of a dark corner.
Like you, I've seen it behave differently on different versions of Unix/different distros of Linux, etc. You just have to accept it.
The exact semantics of "su" have never really been nailed down.
"If you haven't got anything nice to say about anybody come sit next to me." — Alice Roosevelt Longworth
mitnk
Sun Jan 03, 2016 6:45 am
Thanks @disorientedp and @QuietZone for the tips / informations.
jojopi
Sun Jan 03, 2016 7:03 am
To preserve ~/ in non-login sessions started via sudo, add to /etc/sudoers using sudo visudo:
Defaults        env_keep += "HOME"
I personally like this configuration, but some regard it as having security implications. Also it definitely increases the risk that configuration files under /home/pi/ will be created with root ownership, so you should be comfortable with managing permissions before enabling it.
Return to “Raspberry Pi OS”
