justinwood
sox default device
Wed Aug 01, 2012 1:10 am
Anyone else having issues with "sox"?
I installed it and I get the following errors when running "play test.wav":
play WARN alsa: can't encode 0-bit Unknown or not applicable
play FAIL sox: Sorry, there is no default audio device configured
I did some reading and I should be able to pass sox a default device parameter, however I am not sure where to get that info. None of the options in alsa make sense, I did try passing --default alsa and didnt get anywhere.
Can someone point me at some documentation or give me a hand?
thanks!
Rob Sykes
Re: sox default device
Sun Aug 05, 2012 1:47 pm
Try
AUDIODEV=hw:0 play test.wav
ericvrp
Tue Apr 16, 2013 2:04 pm
I've tried recording with rec/sox and can't find the correct AUDIODEV for my microphone. I think the one I am using now as actually my audio output device. Could anyone help me out finding the right setting for 'rec' on a Raspberry Pi?
rec samples/temp.flac
rec WARN alsa: can't encode 0-bit Unknown or not applicable
rec FAIL formats: can't open input `default': snd_pcm_open error: No such file or directory
AUDIODEV=hw:1 rec samples/temp.flac
rec FAIL sox: Sorry, there is no default audio device configured
AUDIODEV=hw:0 rec -r 16000 samples/temp.flac silence 1 0.2 2% 1 0:00:2 2%
rec FAIL formats: can't open input `hw:0': snd_pcm_open error: No such file or directory
The following command works however:
arecord -D "plughw:1,0" -q -f cd -t wav -d 5
drgeoff
Tue Apr 16, 2013 6:27 pm
ericvrp wrote:I've tried recording with rec/sox and can't find the correct AUDIODEV for my microphone. I think the one I am using now as actually my audio output device. Could anyone help me out finding the right setting for 'rec' on a Raspberry Pi?
What USB microphone or USB interface are you using? What responses do you get to the 'lsusb' and 'lsmod' commands?
kupad
Fri May 03, 2013 4:33 pm
I had the same problem, and solved it like so:
In addition to setting the audio device with the environment variable AUDIODEV with:
> export AUDIODEV=hw:1,0
(hw:1,0 being a typical value for a USB microphone on raspi)
I also had to set the AUDIODRIVER environment variable:
> export AUDIODRIVER=alsa
Then I was able to use rec. I wanted it, over arecord, since it can start recording when it detects sound, and can stop recording when it detects silence.
--kupad
vonzepp
Mon Jul 08, 2013 8:03 pm
Hi
I have also this problem. I tried the listed solution however it doesn't solve my problem. Leaving an error of .
rec FAIL formats: can't open input `hw:1,0': snd_pcm_open error: No such file or directory
Those anyone have ideas about this?
Edit: I managed to fix this. First you need to to arecord -l
Then export AUDIODEV=hw:[insert card number],[insert device number]
ThisNameNotUsed
Thu Apr 21, 2016 7:55 pm
I did all this and went through all the same errors and corrections but I am still left with this error:
rec rectest.wav
rec FAIL formats: can't open output file `rectest.wav': Permission denied
sudo rec rectest.wav
I don't know because I am new to Linux but this might explain something: I had to follow these directions to install a hifi berry amp that I am using: https://www.hifiberry.com/guides/config ... ux-3-18-x/
nixoid
Mon Jan 22, 2018 8:07 pm
Try create file .asoundrc in your home dir with content:
pcm.!default {
  type asym
   playback.pcm {
     type plug
     slave.pcm "hw:0,0"
   capture.pcm {
     type plug
     slave.pcm "hw:1,0"
Who is online
Users browsing this forum: No registered users and 66 guests
