steef27
Domoticz and Raspbian?
Tue Dec 29, 2015 8:47 pm
I have installed Domoticz on my PI, but I also want to use my PI for other purposes. Is it also possible to install Raspbian on the same PI?
jbudd
Re: Domoticz and Raspbian?
Tue Dec 29, 2015 11:51 pm
Not precisely what you are asking for, but you can install Domoticz on Raspbian. There are good instructions at https://www.domoticz.com/wiki/Installin ... ble_Binary
steef27
Wed Dec 30, 2015 8:13 am
Thanks! Instead of using my pi just for Domoticz I also want to use it for more than just this. So instead of using Domoticz as a primary system, I want to use is as a application in for example Noobs. So I can use both Noobs and Domoticz.
Is that possible?
Wed Dec 30, 2015 8:15 am
steef27 wrote:Thanks! Instead of using my pi just for Domoticz I also want to use it for more than just this. So instead of using Domoticz as a primary system, I want to use is as a application in for example Noobs. So I can use both Noobs and Domoticz.
Is that possible?
NOOBS is an installer / chooser it is not an Operating System ;)
In NOOBS installer / chooser it is feasible to add a custom Operating System, read the manual here:
https://github.com/raspberrypi/noobs
The Domoticz download is here:
https://www.domoticz.com/wiki/Raspberry_Pi
Last edited by fruitoftheloom on Wed Dec 30, 2015 9:46 am, edited 1 time in total.
adieu
steef27
Wed Dec 30, 2015 9:33 am
@fruitoftheloom, you are right. I want to use Raspbian as my primary operating system, with the GUI, and install Domoticz on it.
@jbudd, is there some instruction about installing Domoticz with the GUI of Raspbian? I am sorry, but I am not really comfortable with the command line. ;)
Wed Dec 30, 2015 9:45 am
steef27 wrote:@fruitoftheloom, you are right. I want to use Raspbian as my primary operating system, with the GUI, and install Domoticz on it.
..as I stated you make a Custom NOOBS so can have a choice of either Raspbian Jessie or Domoticz
If you install Raspbian Wheezy without using NOOBS
https://www.raspberrypi.org/downloads/raspbian/
.........then you can install Domoticz as all the information is on the Developrs Website:
https://www.domoticz.com/wiki/Installin ... spberry_PI
adieu
jbudd
Wed Dec 30, 2015 11:35 am
@jbudd, is there some instruction about installing Domoticz with the GUI of Raspbian? I am sorry, but I am not really comfortable with the command line.)
But the dollar prompt is the most comforting user interface there is! You might just get to like it.
As far as I know you have to use the command line to run the installation commands, but I don't see any reason not to use a terminal window from the GUI.
Once it is installed you can use Domoticz' web interface.
jb
