syscharger
Restart python script from crontab when it crash or killed
Mon Dec 28, 2015 1:39 am
Added the following in crontab (sudo crontab -e) to check for running of python script (testpython.py) every 5 minutes
If script not running, execute the script (testpython.py)..
But unfortunately, it does not work. Any idea why? Did i miss something. Please advise. Thanks
*/5 * * * * pgrep -f testpython.py || sudo python /home/pi/testpython.py
SonOfAMotherlessGoat
Re: Restart python script from crontab when it crash or kill
Mon Dec 28, 2015 1:47 am
Is the account this cron job runs under able to sudo without a password?
Account Inactive
syscharger
Mon Dec 28, 2015 1:57 am
SonOfAMotherlessGoat wrote:Is the account this cron job runs under able to sudo without a password?
Yes. able to.
i tried similar code below, no problem.
*/5 * * * * sudo python /home/pi/testpython.py
syscharger
Mon Dec 28, 2015 4:18 am
Is there alternative solution? If not using crontab.
Mon Dec 28, 2015 10:20 am
syscharger wrote:Is there alternative solution? If not using crontab.
Add a cron file in /etc/cron.d, if you have php5 installed there's an example file in there.
The simplest way to keep a python script running is
#!/bin/bash
until (/home/pi/thingtokeepgettingrestartedwhenitdies.py);
do
sleep 30m # wait half an hour and give it another go.
done;
rayjoh
Mon Dec 28, 2015 11:58 am
It might be that sudo denies cronjobs. Add this line in /etc/sudoers, substitute "rj" with your username.
Defaults:rj   !requiretty
-- Raymond
alexeames
Mon Dec 28, 2015 12:20 pm
don't you need to include the full path to python in your cron job?
cron can be exceedingly fussy
Alex Eames RasPi.TV, RasP.iO
QuietZone
Mon Dec 28, 2015 11:30 pm
alexeames wrote:don't you need to include the full path to python in your cron job?
Nope.
Yes, but this isn't one of them.
"If you haven't got anything nice to say about anybody come sit next to me." — Alice Roosevelt Longworth
jjex22
Tue Dec 29, 2015 2:04 am
Just a side note, that It also occurs to me that python is pretty good at exceptions, and some defensive programming combined with exploring recent crashes may help more in the long term, so that a resurrection script becomes more of a backup?
I had the idea for a single board computer in every seat on airplanes... but it all just seemed a bit Pi in the Sky!
mosespi
Tue Dec 29, 2015 5:25 am
As jjex22 mentioned you should try to make it more robust.. but a simple wrapper script using bash should ensure a restart if it does crash. Very simple code below, so simple its almost always going to work.. run it from rc.local if you wish, and keep the sleep in there just in case your script really hard crashes and refuses to start, it will keep it from restarting too fast and possibly using up most of your system resources.
And I missed reading Dougie's prior post.. this is a similar variant.
Regards,
-Moses
#!/bin/sh
while [ 1 ]
do
        /home/pi/blablayourpythoncommand.py or whatever
        sleep 10
done
Power problems? MoPower UPS for the Pi
http://www.allspectrum.com/mopower/
jaizan
Re: Restart python script from crontab when it crash or killed
Thu Oct 24, 2019 8:04 pm
Apologies for the dumb questions. I have PrivateEyePi running, but it drops out every few weeks. I'm trying to figure out how to make it restart if necessary.
1 Would something like the following work ?
2 Do I just put this in my CRON file ?
3 Is the example below just valid for something in the PI folder, so I need the correct path for restarter ?
#!/bin/sh
while [ 1 ]
do
/home/pi/restarter.py or whatever
sleep 10
done
Thu Oct 24, 2019 8:18 pm
Use a systemd service file. /etc/systemd/system/privatepi.service
[Unit]
Description=Private Pie server
[Service]
ExecStart=/usr/bin/python3 /home/pi/testpython.py
User=pi
Restart=always
RestartSec=360
StartLimitInterval=720
StartLimitBurst=10
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=PrivEye
[Install]
WantedBy=multi-user.target
If it absolutely must run as root remove the User=pi line (it probably doesn't need sudo most thing don't).
Enable that for the next boot with sudo systemctl enable privatepi
Start it now with sudo systemctl start privatepi
Test the restart with
sudo systemctl status privatepi
sudo killall testpython.py
