SpaceCowboy
Kernel Upgrade Issue
Sun Dec 27, 2015 1:27 am
I upgraded my kernel from 3.18.7-v7+ to 4.1.13-v7+. Before the upgrade everything was running fine on boot up. Now after the upgrade, I'm getting the following error:
Starting advanced IEEE 802.11 management: hostapd failed!
Has anyone had this issue or know of a resolution.
Re: Kernel Upgrade Issue
Sun Dec 27, 2015 9:33 am
Were you running a special kernel to run your system as a WiFi access point?
Is your network working?
If the answers are: no & yes then ignore the error.
If the anwers are: yes & no then you'll need to redo the stuff to get your access point running again.
SpaceCowboy
Sun Dec 27, 2015 4:17 pm
How about yes and yes :)
Yes... using as an access point.
Yes... my network is functioning properly other than the access point.
Sun Dec 27, 2015 5:43 pm
Then you need to re-do the kernel/kernel module modifications that you've done to get your AP running.
SpaceCowboy
Sun Dec 27, 2015 9:39 pm
Got it working. Looks like there was an updated driver to go with the Kernel that wasn't included in the 4.1.13-v7+ package.
