Fri Dec 25, 2015 11:42 am
What uses 5V on the B+ / 2B & might put an upper limit on Vin? There's the onboard 3V3 / 1V8 regulator 2306KE that's got a recommended max 5V5, absolute max 6V5, so the BCM2836 will be safe.
Then there's HDMI & downstream USB to consider. The USB current limit switch 2552 again has max recommended 5V5, so as long as you don't plug any USB devices or HDMI monitor in you should be OK, at least as far as plugging in the PSU to see what the output voltage actually is with a light load.
Alternatively, load the PSU with a 5W 5R resistor & see what the output voltage really is. Oh yes, and as gordon77 points out, put the resistor at the end of your intended cable & measure there.
