pteeson
RPi2 + Raspbian + openVPN serve + missing Easy-RSA
Thu Dec 24, 2015 2:56 am
I am working through installing openVPN server on my RPi2 and am stuck.
There are several good tutorials and I've been following the steps in this one:
<http://www.bbc.com/news/technology-33548728>. The others have the same steps.
Apparently they are all now out of date wrt easy-rsa.
After doing the usual sudo apt-get update && sudo apt-get upgrade
I moved on to sudo apt-get install openvpn. This appeared to work.
The next step is to generate keys using Easy-RSA.
cp -r /usr/share/doc/openvpn/examples/easy-rsa/2.0 /etc/openvpn/easy-rsa
No such file or directory.
I did some digging and openVPN says that it's no longer part of the main project.
It's now a sub-project. I found it here: <https://github.com/OpenVPN/easy-rsa>
I have no idea how to add it to whatever data base apt-get uses.
Yes I looked at the Debian Package Management docs and got lost.
Please point me at a simple example of how to add easy-rsa to the apt db.
TIA
respect...
Peter
lmarmisa
Re: RPi2 + Raspbian + openVPN serve + missing Easy-RSA
Fri Dec 25, 2015 5:03 am
Try:
sudo apt-get install easy-rsa
rrichiez
Thu Dec 31, 2015 4:50 pm
Hey have you gotten openvpn to work? if so please give me heads up on what script or page, op system you used to get it worked . I think I have tried every one out there with no luck... please help
rrichiez
thanks before hand
Thu Dec 31, 2015 7:55 pm
lmarmisa wrote:Try:
There's no separate easy-rsa package. You'll find it in /usr/share/easy-rsa after installing the openvpn package.
davidcoton
Fri Jan 01, 2016 1:51 am
Dougie: Read the OP. I don't know if that is right or not, but if it is, your answer is not helpful.
Signature retired
Fri Jan 01, 2016 2:28 am
You have to read the docs, make a directory (mkdir -p /etc/openvpn/easy-rsa) and copy the easy-rsa scripts (cp -R /usr/share/easy-rsa /etc/openvpn/easy-rsa). They then work just fine. The hard part of getting easy-rsa to run is defining all the junk in ../easy-rsa/vars file.
export KEY_COUNTRY="GB"
export KEY_PROVINCE="Hampshire"
export KEY_CITY="Basingstoke"
export KEY_ORG="Example-Organisation"
export KEY_EMAIL="example@example.co.uk"
export KEY_CN="Example-Canonical-Name"
export KEY_NAME="Example"
export KEY_OU="Example-Domain"
pteeson
Fri Jan 01, 2016 10:05 pm
I took a spare SD card and formatted it and installed Raspbian from the NOOBS 1.5 zip.
After which I did the usual sudo apt-ge update && sudo apt-ge upgrade
and then sudo apt-gt install openvpn
From the tail of the log for sudo apt-get install openvpn
[ ok ] Restarting virtual private network daemon.:.
Setting up easy-rsa (2.2.2-1) ...
Setting up opensc (0.14.0-2) ...
Processing triggers for libc-bin (2.19-18+deb8u1) ...
Processing triggers for systemd (215-17+deb8u2) ...
pi@raspberrypi:~ $ sudo -s
root@raspberrypi:/home/pi# cp -r /usr/share/doc/openvpn/examples/easy-rsa/2.0 /etc/openvpn/easy-rsa
cp: cannot stat ‘/usr/share/doc/openvpn/examples/easy-rsa/2.0’: No such file or directory
root@raspberrypi:/home/pi# ls /usr/share/doc/openvpn/examples/
sample-config-files sample-keys sample-scripts
!!!! So as I stated in the OP the instructions in the tutorials are not up to date.!!!!
pteeson
Re: RPi2 + Raspbian + openVPN serve + missing Easy-RSA SOLVE
Fri Jan 01, 2016 10:11 pm
However this command does work as per Lawson's helpful post.
root@raspberrypi:/home/pi# cp -R /usr/share/easy-rsa /etc/openvpn/easy-rsa
So thanks to all who replied and hopefully this will document where the dirs now live.
pteeson
Re: RPi2 + Raspbian + openVPN SOLVED serve + missing Easy-RS
Fri Jan 01, 2016 10:15 pm
rrichiez wrote:Hey have you gotten openvpn to work? if so please give me heads up on what script or page, op system you used to get it worked . I think I have tried every one out there with no luck... please help
rrichiez
thanks before hand
I installed Raspian from the NOOBS zip file as per the instructions.
And followed the instructions in this tutorial
However note the amendment in the previous post to this.....
I've stopped for today but will post when I get it working.
Fri Jan 01, 2016 10:23 pm
You have to remember that tutorial on the BBC was produced by a journalist based on stuff someone technical had told her in the green room or in a pre-production meeting. It's no surprise that it has an error in it. Also it was probably done before Jessie went generally available so things may have moved.
pteeson
Fri Jan 01, 2016 10:38 pm
Plausible. But there are at least 2 other tutorials that state the same thing.
This is one of the eternal problems with documentation - it is almost always post-factum and done as a volunteer effort.
Actually the relevant tutorials themselves, as far as I have read them, are pretty good.
I note there is a Debian OpenVPN Wiki here <https://wiki.debian.org/OpenVPN>.
I'll take a look and see if there is something that would be relevant for Raspbian.
malicious
Sun Jan 03, 2016 3:30 am
There is no need to copy the easy-rsa directory and files manually anymore. In /usr/share/doc/easy-rsa, there is a file README.Debian(Debian is the distribution Raspbian is based on) explaining the new way to start using easy-rsa. Rather than copy by hand, you call the script /usr/bin/make-cadir. For example, if one wants a working copy of easy-rsa in /etc/openvpn/, the commands would be:
make-cadir /etc/openvpn/easy-rsa
cd /etc/openvpn/easy-rsa
You should be able to proceed with creating a certificate authority and whatnot from there.
Return to “Advanced users”
