Obel
How to update rrd database in python
Mon Dec 21, 2015 3:06 pm
I am new to the programing and I am using already created scripts, I am trying to update my rrdtool database in python. I have manage to create below code which don’t come back to me with any errors but when I am trying to generate a graph it don’t contain any data.
#!/usr/bin/python
#modules
import sys
import os
import time
import rrdtool
import Adafruit_DHT as dht
#assign data
h,t = dht.read_retry(dht.DHT22, 22)
#display data
print 'Temp={0:0.1f}*C'.format(t, h)
print 'Humidity={1:0.1f}%'.format(t,h)
#update database
data = "N:h:t"
ret = rrdtool.update("%s/humidity.rrd" % (os.path.dirname(os.path.abspath(__file__))),data)
if ret:
print rrdtool.error()
time.sleep(300)
Below my data base specification:
#! /bin/bash
rrdtool create humidity.rrd \
--start "01/01/2015" \
--step 300 \
DS:th_dht22:GAUGE:1200:-40:100 \
DS:hm_dht22:GAUGE:1200:-40:100 \
RRA:AVERAGE:0.5:1:288 \
RRA:AVERAGE:0.5:6:336 \
RRA:AVERAGE:0.5:24:372 \
RRA:AVERAGE:0.5:144:732 \
RRA:MIN:0.5:1:288 \
RRA:MIN:0.5:6:336 \
RRA:MIN:0.5:24:372 \
RRA:MIN:0.5:144:732 \
RRA:MAX:0.5:1:288 \
RRA:MAX:0.5:6:336 \
RRA:MAX:0.5:24:372 \
RRA:MAX:0.5:144:732 \
danjperron
Re: How to update rrd database in python
Mon Dec 21, 2015 3:26 pm
Check my step by step method .
I do have in my python script code to update the rddtool with Highcharts
viewtopic.php?p=672576#p672576
Obel
Wed Jan 13, 2016 1:09 pm
yea, based on your script i have minimaze my and it worked.
Again thank you
#!/usr/bin/python
#laduje moduly
import sys
import os
import time
import rrdtool
import subprocess
#przypisuje
#display data
#RRD TOOL UPDATE
def Validate(value):
  if value == None:
    return ":U"
  else:
    return ":{}".format(value)
#create text string to insert data
rdata = "N" + Validate(h)
#now let insert it into the rddtool data
fileRrdtool = "/home/pi/Hum/humidity.rrd"
subprocess.Popen(["/usr/bin/rrdtool","update",fileRrdtool,rdata])
sufenta
Thu Apr 21, 2016 8:21 am
I hope somone is able to help me. When i use your code i get an error:
Temp=20.0*C
Humidity=21.0%
ERROR: /home/pi/Test/test/humidity.rrd: expected 2 data source readings (got 1) from N
any ideas?
sufenta
Sun Apr 24, 2016 8:12 am
no one an idea?
tom.slick
Sun Apr 24, 2016 8:48 am
sufenta wrote:I hope somone is able to help me. When i use your code i get an error:
Temp=20.0*C
Humidity=21.0%
any ideas?
You only pass the value h. What happend to t?
original
data = "N:h:t"
now
danjperron
Sun Apr 24, 2016 12:31 pm
The validate function is there to check if the sensor return something
if not it will return ':U' => unknow
ef Validate(value):
  if value == None:
    return ":U"
  else:
And yes if your rrdtool needs 3 inputs you should send all your inputs.
rdata = "N" + Validate(cpuTemp) + Validate(sensorData[0]) + Validate(sensorData[1])
fileRrdtool = "/home/pi/temperatures.rrd"
If you add some input data at your rrd database you could check using the info command
ex:
pi@Pi2 ~ $ rrdtool info temperatures.rrd
filename = "temperatures.rrd"
rrd_version = "0003"
step = 300
last_update = 1420088400
header_size = 5096
ds[th_cpu].index = 0
ds[th_cpu].type = "GAUGE"
ds[th_cpu].minimal_heartbeat = 1200
ds[th_cpu].min = -4,0000000000e+01
ds[th_cpu].max = 1,0000000000e+02
ds[th_cpu].last_ds = "U"
ds[th_cpu].value = 0,0000000000e+00
ds[th_cpu].unknown_sec = 0
ds[th_dht22].index = 1
ds[th_dht22].type = "GAUGE"
ds[th_dht22].minimal_heartbeat = 1200
ds[th_dht22].min = -4,0000000000e+01
ds[th_dht22].max = 1,0000000000e+02
ds[th_dht22].last_ds = "U"
ds[th_dht22].value = 0,0000000000e+00
ds[th_dht22].unknown_sec = 0
ds[hm_dht22].index = 2
ds[hm_dht22].type = "GAUGE"
ds[hm_dht22].minimal_heartbeat = 1200
ds[hm_dht22].min = -4,0000000000e+01
ds[hm_dht22].max = 1,0000000000e+02
ds[hm_dht22].last_ds = "U"
ds[hm_dht22].value = 0,0000000000e+00
ds[hm_dht22].unknown_sec = 0
On this example I do have 3 inputs. Cpu temperature, DHT22 Temperature and DHT22 humidity.
Maybe it is a good thing to read the rrdtool doc.
Daniel
Return to “Python”
