lilzz wrote:...I want to output the std::string the first part of inner map...
Which std::string? The
key to the inner std::map or the second part of the std::pair (that is the
value in the inner std::map)?
You don't appear to be understanding what is happening when you iterate over the contents of a container. Your code snippet is a map of maps. For example the contents of mfvs could look like this:-
1 : { "jack" : { 1, "frost }, "jill" : { 2, "snow" }, "jane" : { 3, "sleet" } },
2 : { "john" : { 1, "sun" }, "kate" : { 1, "hail" } },
Anyway the code would look like this:
std::map<int, std::map<std::string, std::pair<int, std::string>>>mfvs;
for (const auto& iter : mfvs)
// iter.second is the inner std::map ... it has no member 'first' ... you need to iterate over the inner std::map as it (potentially) holds multiple values.
for (const auto& iter2 : iter.second)
// to print out the std::string 'key's for the inner maps ...
// note: how are you going to know which outer std::map these values belong to.
std::cout << iter2.first << "\n";
// to print out the std::string that is the second part of the std::pair (that is the 'value' in the inner std::map)
std::cout << iter2.second.second << "\n";
