caporeira
Haguichi on Raspbian Jessie
Thu Dec 17, 2015 8:16 pm
I can't find Hamachi with GUI in Jessie. I'm searching on repositorium but nothing :(
Re: Haguichi on Raspbian Jessie
Thu Dec 17, 2015 10:09 pm
caporeira wrote:Hi,
https://www.jgomez.net/install-hamachi- ... i-raspbian
RPi 4B 4GB (SSD Boot)..
caporeira
Thu Dec 17, 2015 10:39 pm
Thank you!
But what I'm doing wrong ?
pi@raspberrypi:~ $ sudo dpkg –force-architecture –force-depends -i logmein-hamac                                        hi_2.1.0.139-1_armel.deb
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
pi@raspberrypi:~ $
https://www.dropbox.com/s/lywb04i4lc3o5 ... 2.jpg?dl=0
Fri Dec 18, 2015 7:05 am
caporeira wrote:Thank you!
pi@raspberrypi:~ $
It does state to ensure you use correct file :?
sudo wget https://secure.logmein.com/labs/logmein ... _armel.deb
...should be
sudo wget https://secure.logmein.com/labs/logmein ... _armhf.deb
sudo dpkg –force-architecture –force-depends -i logmein-hamachi_2.1.0.139-1_armel.deb
....should be
]sudo dpkg –force-architecture –force-depends -i logmein-hamachi_2.1.0.139-1_armhf.deb
caporeira
Sat Dec 19, 2015 10:59 am
Solved. Thank you.
Return to “Beginners”
