I've tried to install SNMPD using apt but during installation and on service start/restart I receive always that error: "pcilib: Cannot open /proc/bus/pci". The daemon is not running (googling I've found that someone reported the service runs even the error appears). Following the two answers at http://stackoverflow.com/questions/9470 ... oc-bus-pci I've tried to compile (with modification and/or both patch) net-snmp-5.7.1 - 5.7.2 and 5.7.3 but without success: the error is gone but the service is still not running, even if started manually (On service start I did not receive any response). Here the steps I've made (maybe there's something wrong):
unzip net-snmp source
./configure
patch < "patch.file"
make
make install
sudo /etc/init.d/snmpd restart -or- sudo service snmpd restart
(both without response or error)
and using
ps -A | grep snmpd -or- sudo service snmpd status
i did not receive any response:
pi@raspberrypi ~ $ sudo service snmpd restart
pi@raspberrypi ~ $
Hope someone can help to get it work
