dott_ing
Blink LEDs python
Fri Dec 11, 2015 8:52 am
Hello, I have a problem that I can not find solution. I have to turn on the LEDs, with the GPIO interface, simultaneously but with different flashing frequencies using a python script. How can I do? Thank you all for answers
elParaguayo
Re: Blink LEDs python
Fri Dec 11, 2015 9:14 am
What have you tried so far? You'll learn more if we help you with your own code rather than just give you an answer.
Is this a homework exercise?
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Massi
Fri Dec 11, 2015 9:21 am
dott_ing wrote:Hello, I have a problem that I can not find solution. I have to turn on the LEDs, with the GPIO interface, simultaneously but with different flashing frequencies using a python script. How can I do? Thank you all for answers
just to make it a little more interesting, i'd go with pigpio's waves.
afaik you can create different waves on different gpios (eventually chain them or repeat them if you need) and then start all of them together.
This would be nice :)
dott_ing
Fri Dec 11, 2015 9:35 am
elParaguayo wrote:What have you tried so far? You'll learn more if we help you with your own code rather than just give you an answer.
It is for a personal project. The code I wrote only achieves a turn on the LEDs sequentially and not simultaneously.
elParaguayo
Fri Dec 11, 2015 9:58 am
There are a few ways of doing it. Massi's suggested one which I've never used.
Other ideas could be:
  • Use the modulo operator to check whether a counter is a multiple of your desired interval (e.g. if you've got two LEDs, one flashes every 5 intervals and the other every 3 then you use the modulo operator on the counter and, when this equals zero, change the state of the LED).
  • Set up a separate thread for each LED. This may be overkill if you're new to python.
Why don't you post your code and we'll give you some pointers.
Massi
Fri Dec 11, 2015 10:08 am
elParaguayo wrote:There are a few ways of doing it. Massi's suggested one which I've never used.
me too
that's why i'd use it :) (*)
Yes, but:
- a common period can be difficult if he has many leds
- cpu wasting if you need to have a good precision
- in every case, it will not be very precise, since if you have to toggle more leds together you need to do that sequentially
[*]Set up a separate thread for each LED. This may be overkill if you're new to python.[/list]
Probably this is the correct way.
I think this is even far easier that build up waves :)
(*) i admit now i'm waiting for joan to join the topic and do his magic with some code :)
RST8
Fri Dec 11, 2015 10:12 am
There are a number of ways to do it, but how about running each LED on a different thread ?
You'd need to do some clean up to stop things and replace the print with your GPIO code, but this might be one approach:
import threading
import time
class FlashLed(threading.Thread):
    def __init__(self, id,pauseTime):
        threading.Thread.__init__(self)
        self.pauseTime = pauseTime
        self .id = id
    def run (self):
        while True:
            print self.id, "On"
            print
            time.sleep(self.pauseTime)
            print self.id, "Off"
            print
for j in range (1,4):
    pauseTime = j*1.5
    led = FlashLed(str(j),pauseTime)
    led.daemon
    led.start()
time.sleep(30)
Joe
dott_ing
Fri Dec 11, 2015 10:23 am
This is my code:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7, GPIO.OUT)
GPIO.setup(11, GPIO.OUT)
GPIO.setup(13, GPIO.OUT)
GPIO.setup(15, GPIO.OUT)
def activateLED(pin,delay):
  GPIO.output(pin, GPIO.HIGH)
  time.sleep(delay)
  GPIO.output(pin, GPIO.LOW)
  time.sleep(delay)
  return;
while(1):
    activateLED(7,1)
    activateLED(11,2)
    activateLED(13,3)
    activateLED(15,4)
GPIO.cleanup()
How could I change to turn on 4 LEDs simultaneously?
elParaguayo
Fri Dec 11, 2015 10:27 am
Massi wrote:
Yes, but:
Indeed. I wouldn't say it's perfect but, for a beginner it may be easier than threads and introduces some good basic skills.
If it was just two LEDs, you could do something like this:
from time import sleep
int_a = 5  ## First interval
int_b = 3  ## Second interval
state_a = True  # Start with LED on
state_b = True  # Start with LED on
for x in range(100):
    print ("LED A: {}\tLED B: {}".format(state_a, state_b))
    # Use the modulus function to check if x is a multiple of our
    # deisred intervals. If it is, invert the state.
    if not x % int_a:
        state_a = not state_a
    if not x % int_b:
        state_b = not state_b
    sleep(0.05)
This should show LED A having a period of 5 and LED B a period of 3.
But I agree, the code would get unwieldy the more LEDs you wanted to add and the common period gets harder. If it were me, I'd go down the thread route, but I just wanted to put some options out there.
Me too.
elParaguayo
Fri Dec 11, 2015 10:29 am
RST8 wrote:
import threading
import time
        self .id = id
    def run (self):
        while True:
            print self.id, "On"
            print
            print
    pauseTime = j*1.5
    led.daemon
    led.start()
time.sleep(30)
Joe
I think you may need
led.daemon = True
RST8
Fri Dec 11, 2015 10:48 am
elParaguayo wrote:
RST8 wrote:
import threading
import time
        self .id = id
    def run (self):
        while True:
            print self.id, "On"
            print
            print
    pauseTime = j*1.5
    led.daemon
    led.start()
time.sleep(30)
Joe
led.daemon = True
Possibly, depending on when you want to exit and how you clean up the threads. Perhaps doing the while True wasn't the best example in this case, but just enough code to get going.
Joe
elParaguayo
Fri Dec 11, 2015 11:07 am
What I meant was, doing "led.daemon" does nothing in your code. "daemon" is a property of the thread so your line is just retrieving that value rather than setting it.
The two ways (that I know of) to daemonise the thread are:
led.daemon = True
# or
led.setDaemon(True)
dott_ing
Fri Dec 11, 2015 11:13 am
can anyone help me to modify the code I posted above? Thank you all
RST8
Fri Dec 11, 2015 11:50 am
elParaguayo wrote:What I meant was, doing "led.daemon" does nothing in your code. "daemon" is a property of the thread so your line is just retrieving that value rather than setting it.
led.daemon = True
# or
led.setDaemon(True)
Fair point, always good to have a code review before submission:-)
Joe
dott_ing
Fri Dec 11, 2015 12:54 pm
I can not change my code. I wanted to put an LED in thread. And then start 4 threads simultaneously. How can I do?
elParaguayo
Fri Dec 11, 2015 12:59 pm
I don't like doing this as I'd much rather see you try to adapt your code. But try this...
import threading
import time
# This is a list in the form (pin number, delay)
LEDS = [(7, 1), (11, 2), (13, 3), (15,4)]
    def __init__(self, pin, pauseTime):
        self.pin = pin
        GPIO.setup(self.pin, GPIO.OUT)
    def run (self):
        while True:
            GPIO.output(self.pin, GPIO.HIGH)
            GPIO.output(self.pin, GPIO.LOW)
for pin, delay in LEDS:
    led = FlashLed(pin, delay)
    led.daemon = True
    led.start()
try:
    while True:
        time.sleep(1)
except KeyboardInterrupt:
    print "User pressed ctrl+c"
finally:
    GPIO.cleanup()
I can't test it so there may be typos.
dott_ing
Fri Dec 11, 2015 1:26 pm
elParaguayo wrote:I don't like doing this as I'd much rather see you try to adapt your code. But try this...
import threading
import time
        self.pin = pin
    def run (self):
        while True:
    led.daemon = True
    led.start()
try:
    while True:
        time.sleep(1)
finally:
    GPIO.cleanup()
Thank you very much. Now I try and let you know.
gordon77
Fri Dec 11, 2015 2:01 pm
Here's a program l did a while ago it may give you some ideas
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(25,GPIO.OUT)
GPIO.setup(24,GPIO.OUT)
GPIO.setup(23,GPIO.IN)
# set timings
t1h = 5
t1l = 1
t2 = 1.5
t3 = 1
t4 = .5
t5 = 1
t6 = .5
t7 = 1
led25 = False
start = 0
print "  Press Ctrl & C to Quit"
def time25(led25,t1h,t1l,start):
   if (led25 == True and time.time() - start > t1h) or (led25 == False and time.time() - start > t1l):
      if led25 == True:
         led25 = False
      else:
         led25 = True
      GPIO.output(25, led25)
      start = time.time()
   return (led25,start)
def time24(th,tl,led25,t1h,t1l,start):
   GPIO.output(24, True)
   now = time.time()
   while time.time() - now < th:
      led25,start = time25(led25,t1h,t1l,start)
   GPIO.output(24, False)
   now = time.time()
   while time.time() - now < tl:
   return(led25,start)
try:
   while True:
      if GPIO.input(23)== False:
         led25,start = time24(t2,t3,led25,t1h,t1l,start)
         led25,start = time24(t4,t5,led25,t1h,t1l,start)
         led25,start = time24(t6,t7,led25,t1h,t1l,start)
  print "  Quit"
  GPIO.cleanup()
bentejuy
Sat Dec 12, 2015 12:03 am
I'm developing a module that can simulate this effect or other effects more complex easily, but first you need have installed the raspybot module.
This is an example:
import time
from raspybot.devices.logic import Blinker
from raspybot.io.interface import InterfaceManager, InterfaceGPIO
# This function is a callback of the "Blinker" object and receives two
# parameters each time the value must change. Each bit of the value
# represents a channel, you can change the state of a channel simply
# changed the value at the bit level.
def do_effect(value, count):
	result = 0
	result |= 0b0001 if count % 2 else 0
	result |= 0b0010 if count % 3 else 0
	result |= 0b0100 if count % 5 else 0
	result |= 0b1000 if count % 7 else 0
	return result
manager = InterfaceManager()											# Initializes the interfaces manager
iface = InterfaceGPIO(manager, pinout=(19, 16, 26, 20))					# Defines the GPIO output channels
try:
	# Create and associate the "Blinker" object with the interface and its channels
	blinker = Blinker(iface, delay=.5, initial=0, checker=do_effect)
	blinker.start()
	while True:
		time.sleep(1)
	pass
finally:
	manager.delete(iface)
	manager.cleanup()
On this page you can see more example how it works : http://raspybot.com/articles/2015/04/09 ... art-i.html
Cheers!.
Return to “Python”
