apjoshi
Enable OpenGL on Raspbian Jessie for OpenCV
Wed Dec 09, 2015 9:15 am
Thanks to "moslemk" for solving this error...
GdkGLExt-WARNING **: Window system doesn't support OpenGL.
OpenGL is not enabled on Raspbian Jessie 8.0 by default.
In order to enable OpenGL you need to instal "libgl1-mesa-dri"
sudo apt-get install libgl1-mesa-dri
OpenCV work perfect after installing the above mentioned library.
I cannot believe Devs at RaspberryPi missed such an important library in Raspbian Jessie that have caused so many hours of trouble] to its users...
here is original link for solution
viewtopic.php?t=121892&p826990
go to page-4
il_diavolo
Re: Enable OpenGL on Raspbian Jessie for OpenCV
Fri Dec 11, 2015 10:11 pm
Yes, I found that installing libgl1-mesa-dri did work when using a connected monitor and "startx". However it would not work headless (on my set-up) with TightVNC with its virtual desktops. My solution to running Opencv headless (necessary with my robot) is to use x11vnc which mirrors the "true" desktop.
If anyone has resolved this using TightVNC I would be interested to hear.
il.diavolo
Who is online
Users browsing this forum: peekay17 and 19 guests
