FatalXception
LED's for PiZero?
Tue Dec 08, 2015 7:13 pm
I'm planning a project that will require up to 8 LED's. All the LED's will have the same color and brightness, but I want the ability to change either. I initially thought Neopixels would be a good product to use, but the project is for a PiZero, and there seem to be a lot red and yellow flags when I read about Neopixels and Raspberries. The LED's will not be evenly spaced, so I cannot just use an 8-LED strip- I would need to group in pairs. I'd appreciate any advice on this. There are simpler ways of solving the need this project fixes (car dashboard illumination), but I chose it because I wanted a Pi Zero project. Please advise with component suggestions- I appreciate it!
mikronauts
Re: LED's for PiZero?
Tue Dec 08, 2015 7:27 pm
Get two of the Adafruit "servo driver" boards.
They use an LED driver chip.
Two boards = 32 outputs
That will drive 10x RGB LED's, and have two outputs left over for single color LED's.
FatalXception wrote:I'm planning a project that will require up to 8 LED's. All the LED's will have the same color and brightness, but I want the ability to change either. I initially thought Neopixels would be a good product to use, but the project is for a PiZero, and there seem to be a lot red and yellow flags when I read about Neopixels and Raspberries. The LED's will not be evenly spaced, so I cannot just use an 8-LED strip- I would need to group in pairs. I'd appreciate any advice on this. There are simpler ways of solving the need this project fixes (car dashboard illumination), but I chose it because I wanted a Pi Zero project. Please advise with component suggestions- I appreciate it!
FatalXception
Tue Dec 08, 2015 8:15 pm
Thanks for the advice! So if I did go with Neopixels, this would drive them, right? I really like how the Adafruit page includes relevant links for those of us who are 'less-experienced'. If I read this right, the one 16-channel board will allow control of 16 PWM LED's, right?
Thanks again!
mikronauts
Tue Dec 08, 2015 9:10 pm
You are welcome.
No, it would not drive NeoPixels.
It would drive the much cheaper four pin RGB LED's (common, r,g,b)
FatalXception wrote:Thanks for the advice! So if I did go with Neopixels, this would drive them, right? I really like how the Adafruit page includes relevant links for those of us who are 'less-experienced'. If I read this right, the one 16-channel board will allow control of 16 PWM LED's, right?
Thanks again!
