Hey guys.
For a project of mine I need to be able to connect and listen to multiple microphones simultaneously. Connecting each microphone and simply listening it is probably really easy (Haven't done it yet, so I can't really judge, but I guess that it will be easy). The problem is that precision is crucial in my project: I somehow need to let the RPi listen to only one microphone in one thread, with all of those threads running in "parallel".
More precise explanation on why I want to do so:
After each Microphone input I receive, which hopefully is every few milliseconds or less, I need to perform some mathematical operations (Autocorrelation and such). I can't allow myself to let those operations put the other microphones input on hold, so I need to let them run in parallel.
Do some of you guys happen to know what layer of hardware I should use to connect the microphones with the RPi in order to achieve what I want to do?
Thanks!
Kind regards,
Flyverse
