Anuskuss
Correctly mount hard drive
Sun Dec 06, 2015 5:28 pm
I recently got a RPi2 and was trying to create a NFS. I installed ntfs-3g and then started to format the hdd with fdisk (had a hidden partition named Hidden NTFS WinRE) and it all went successfully.
Now fsdisk shows a /dev/sda1 with a start of 2048 and an end of 2930277167 (1.4TB). But when I run df -Bm, it shows that only 5902MB (42%) are available. That exactly the available space on my SD card.
What should I do to use the full space of my hdd? I mounted it with
sudo mount -t auto /dev/sda1 /media/hdd1
and created the line
/dev/sda1 /media/hdd1 auto noatime 0 0
in /etc/fstab.
I don't know what I'm doing wrong. I can't put large files on my hdd via samba because it tells me that I don't have enough empty space.
elatllat
Re: Correctly mount hard drive
Mon Dec 07, 2015 8:42 pm
There is no such thing as a "hidden partition" because all space is accounted for (have a look see in GParted) so just use a normal ext4, and use LUKS if you want some security.
to mount your non-indexed partition use;
-o offset=XXXX
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
