JonnyAlpha
Raspberry Pi Certified Educator
Slow and Troublesome WiFi
Sat Dec 05, 2015 1:59 pm
Hi;
I am building and testing a WiFi controlled robot and am having some WiFi problems.
The WiFi dongle is a generic one that came with the Maplins raspberry Pi Kit (No name on the dongle).
Output of iwconfig is here:
wlan0     IEEE 802.11bgn  ESSID:"BTHub4-HKG2"
          Mode:Managed  Frequency:2.462 GHz  Access Point: CC:33:BB:F4:D8:FC
          Bit Rate=6.5 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=29/70  Signal level=-81 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:2   Missed beacon:0
lo        no wireless extensions.
eth0      no wireless extensions.
The bit rate says 6.5mbs which seems painfully slow.
I am using mjpg-streamer to stream a video feed from a web camera mounted on the robot it started having problems with an update of Raspbian but this was fixed by patching mjpg-streamer but the problems have come back.
When the Pi is connected via Ethernet the stream is fine?
I have tried changing channel to channel 1 from 11 on my BT Home Hub Router initially I was getting about 38mbs but then when I ran mjpg-streamer it dropped to 7mbs again?
Do I need to update the firmware in the dongle?
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
Re: Slow and Troublesome WiFi
Sat Dec 05, 2015 2:14 pm
JonnyAlpha wrote:Hi;
Could you post the output of:
lsusb
uname -a
JonnyAlpha
Sat Dec 05, 2015 2:19 pm
Just doing and update and upgrade but will do :-)
Oh and its a Ralink RT5370.
JonnyAlpha
Sat Dec 05, 2015 2:39 pm
Here is the output of lsusb:
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 046d:0825 Logitech, Inc. Webcam C270
and uname -a:
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.18.11+ #781 PREEMPT Tue Apr 21 18:02:18 BST 2015 armv6l GNU/Linux
Sat Dec 05, 2015 2:54 pm
JonnyAlpha wrote:Here is the output of lsusb:
and uname -a:
The RT5370 has always been supported under Raspbian and this blog includes speed comparisions between WiFi and Ethernet
http://www.midwesternmac.com/blogs/jeff ... networking
JonnyAlpha
Sat Dec 05, 2015 3:03 pm
and uname -a:
Thanks for the link but not sure how this helps me? I am using WiFi on a mobile platform so USB to Ethernet is not possible?
gregeric
Sat Dec 05, 2015 3:10 pm
-81dBm ain't lighting up too many bars on the signal strength meter. Maybe worth trying a short USB extension cable to bring the dongle out into fresh air if it's buried in lots of metal on the robot.
JonnyAlpha
Sat Dec 05, 2015 3:37 pm
gregeric wrote:-81dBm ain't lighting up too many bars on the signal strength meter. Maybe worth trying a short USB extension cable to bring the dongle out into fresh air if it's buried in lots of metal on the robot.
Mmm - funny that was my thinking too (although I could not remember whether -81dBm was any good :-)
I ran a USB extension lead and had a little higher but just now I tried out my Mobile Phone Portable Hotspot which I use when its out and about and I get a nice 65Mb/s compared to 24Mb/s using my Home WiFi and USB Extension :-)
Maybe try another channel?
gregeric
Sat Dec 05, 2015 3:39 pm
Nice :D
Yeah worth a shot if it's crowded on the existing.
