I'm using a USB WiFi dongle on my RPi, I have observed that after some time (~1Day) the WiFi goes down and requires me to reboot the rPi whenever that happens, upon going through the syslog I found the following error around the time the rPi went offline:
Dec 4 10:18:24 raspberrypi ifplugd(wlan0)[388]: Link beat lost.
Dec 4 10:18:26 raspberrypi dhcpcd[2538]: wlan0: carrier lost
Dec 4 10:18:26 raspberrypi wpa_supplicant[1529]: wlan0: CTRL-EVENT-DISCONNECTED bssid=c0:4a:00:8d:ad:b2 reason=0
Dec 4 10:18:26 raspberrypi avahi-daemon[2199]: Withdrawing address record for 10.10.0.101 on wlan0.
Dec 4 10:18:26 raspberrypi avahi-daemon[2199]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.10.0.101.
Dec 4 10:18:26 raspberrypi avahi-daemon[2199]: Interface wlan0.IPv4 no longer relevant for mDNS.
Dec 4 10:18:26 raspberrypi dhcpcd[2538]: wlan0: deleting route to 10.10.0.0/24
Dec 4 10:18:26 raspberrypi dhcpcd[2538]: wlan0: deleting default route via 10.10.0.254
Dec 4 10:18:27 raspberrypi ntpd[2083]: Deleting interface #3 wlan0, 10.10.0.101#123, interface stats: received=151, sent=151, dropped=0, active_time=80028 secs
Dec 4 10:18:27 raspberrypi ntpd[2083]: 10.10.0.100 interface 10.10.0.101 -> (none)
Dec 4 10:18:27 raspberrypi ntpd[2083]: peers refreshed
Dec 4 10:18:32 raspberrypi wpa_supplicant[1529]: wlan0: Trying to associate with c0:4a:00:8d:ad:b2 (SSID='TP-LINK_POCKET_3020_8DADB2' freq=2462 MHz)
Dec 4 10:18:32 raspberrypi wpa_supplicant[1529]: wlan0: Association request to the driver failed
Dec 4 10:18:34 raspberrypi ifplugd(wlan0)[388]: Executing '/etc/ifplugd/ifplugd.action wlan0 down'.
Dec 4 10:18:34 raspberrypi wpa_supplicant[1529]: wlan0: CTRL-EVENT-TERMINATING - signal 15 received
Dec 4 10:18:34 raspberrypi ifplugd(wlan0)[388]: Program executed successfully.TIA!
