Hi!
Is it possible to power the Raspberry Pi over a powered USB Hub and use it as Hub at the same time?
If you're powering the Pi by the same hub and disconnect power to the hub to power off the Pi then power backfeed is a non issue.IanK wrote:Some powered USB hubs have an issue in that they backfeed 5v back into the host, power will then be fed into the pi via the micro usb connector and the usb socket.
see http://www.raspberrypi.org/phpBB3/viewt ... pi#p129416 for more details
I got around this by opening up the usb cable and disconnecting the +5v red wire, power is now only fed via the micro usb socket.
