Hello, sounds interesting, but no joy building, or even installing
Info here:
https://pypi.python.org/pypi/simpleaudio/1.0.0
refers to:
https://github.com/hamiltron/simpleaudio
which is a 404 as itś wrong. Looks like itś:
https://github.com/hamiltron/py-simple-audio
Both attempts result in:
/usr/bin/pip run on Thu Dec 3 19:02:01 2015
Downloading/unpacking simpleaudio
Getting page
https://pypi.python.org/simple/simpleaudio/
URLs to search for versions for simpleaudio:
Analyzing links from page
Skipping
https://pypi.python.org/packages/cp33/s ... ae73d427e6 (from
https://pypi.python.org/simple/simpleaudio/) because it is not compatible with this Python
Skipping
https://pypi.python.org/packages/cp33/s ... 98903ae13c (from
Skipping
https://pypi.python.org/packages/cp33/s ... 30f62951cc (from
Skipping
https://pypi.python.org/packages/cp34/s ... e36628cfb1 (from
Skipping
https://pypi.python.org/packages/cp34/s ... 1228dd9bab (from
Skipping
https://pypi.python.org/packages/cp34/s ... a33533671f (from
Skipping
https://pypi.python.org/packages/cp35/s ... 7c91cc580b (from
Skipping
https://pypi.python.org/packages/cp35/s ... 35fcba4a9a (from
Skipping
https://pypi.python.org/packages/cp35/s ... 8e6d1efb22 (from
Found link
https://pypi.python.org/packages/source ... ead7e53fe1 (from
https://pypi.python.org/simple/simpleaudio/), version: 1.0.0
Downloading from URL
Running setup.py (path:/tmp/pip-build-UmFyQK/simpleaudio/setup.py) egg_info for package simpleaudio
File "<string>", line 17, in <module>
File "/tmp/pip-build-UmFyQK/simpleaudio/setup.py", line 40, in <module>
encoding='utf-8') as f:
TypeError: 'encoding' is an invalid keyword argument for this function
Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-UmFyQK/simpleaudio
Exception information:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1230, in prepare_files
req_to_install.run_egg_info()
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 326, in run_egg_info
command_desc='python setup.py egg_info')
File "/usr/lib/python2.7/dist-packages/pip/util.py", line 716, in call_subprocess
% (command_desc, proc.returncode, cwd))
InstallationError: Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-UmFyQK/simpleaudio
Any ideas please?
