Easiest would be a Compute Module, with its development board, and the additional camera adapter kit.
StevenK wrote:I am interested in doing a project involving aerial photography that would require mounting two cameras on a quad-copter that could take simultaneous images. I wanted to find out if this is possible and, if so, the simplest way to accomplish it. Weight is an issue and I would want to minimize it, so the main issue would be whether I could run the two cameras off of one Pi. I have a RPi 2B and an RPi Zero. It would be great to save weight using the Zero, but I imagine it would be more difficult to run two cameras on it. One camera I am thinking of using is the Infragram DIY Plant Analysis Webcam, which is USB ... so I thought I may be able to use that and also a camera board on the Pi2. I am a beginner, though, and this is my first RPi project, so I'd be interested to hear thoughts and ideas on how I can accomplish this, and issues I should be aware of. I'd also be interested in thoughts on battery power (I only need 20-30 minutes of operating time) Thanks!
