MauroRC
ERROR RUNNING PROGRAM TO AUTOMATICALLY START
Fri Nov 27, 2015 1:22 am
Hello people.
I have a program in Python and I want to run automatically when you start the Raspberry Pi. I found an online code to do that, but I throw error, the error that throws me is the following:
insserv: warning: script 'K01Color' missing LSB tags and overrides
insserv: warning: script 'Color' missing LSB tags and overrides
The code I'm using is as follows:
#! / bin / sh
# /etc/init.d/Color
case "$ 1" in
         start)
           echo "Starting"
           / usr / bin / python /home/pi/Arduino.py
         stop)
           echo "Stopping program"
           echo "Usage: /etc/init.d/Color {start | stop}"
           exit 1
that C
exit 0
-------------------------END CODE--------------------------------------
¿Does anyone know how to fix this error?
AndyD
Re: ERROR RUNNING PROGRAM TO AUTOMATICALLY START
Fri Nov 27, 2015 1:41 am
If you have a look in /etc/init.d/ on you Raspberry Pi, there is a file called skeleton (less /etc/init.d/skeleton) that contains an example of a well formed init.d service. It is warning you that the LSB tags are missing. They look like this:-
### BEGIN INIT INFO
# Provides:          skeleton
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Example initscript
# Description:       This file should be used to construct scripts to be
#                    placed in /etc/init.d.
### END INIT INFO
and describe when the service should run.
If you are using Raspbian Jessie, I would suggest having a look at the systemd services. They are considerably easier to write.
Return to “Python”
