God
DVI Splitter?
Fri Jul 27, 2012 10:51 pm
Hi Folks
I am going to need a DVI splitter to use my Pi with my monitor. I have looked on amazon and ebay but feel slightly confused….
Clearly I need a splitter that provides 2 female inputs for my PI and PC to attach to one male connector for my monitor… However splitters that look like this appear to have descriptions of one input to two outputs.. effectively being used in the reverse of what I want… they seem to be built to show one image on two monitors rather than two sources to one monitor?
What am I missing ? Can anyone point me at a low cost splitter that will allow me to plug my PI and PC into a pair of connectors that terminate in to one for my monitor?
Cheers
Peter
mahjongg
Re: DVI Splitter?
Sat Jul 28, 2012 12:28 am
well, what you describe is normally not called a splitter but a switch.
God
Re: DVI Splitter /Switch?
Sat Jul 28, 2012 3:22 am
Yup, that is true, I realised that while I was waiting for my post to be approved... So can anyone point me in the direction of a low cost DVI switch?
God
Re: DVI Splitter?
Sat Jul 28, 2012 3:32 am
This is about the cheapest I have seen, around a tenner.
http://www.amazon.co.uk/HQ-2-Port-DVI-I ... roduct_top
johnbeetem
Re: DVI Splitter?
Sat Jul 28, 2012 4:26 am
I think this is the one I'm using, from Amazon USA: http://www.amazon.com/Ultra-High-Perfor ... B0015YWKYY
At least it looks just like it -- there's no brand name in this price range. I use it to switch between two PCs and RasPi or BeagleBoard. It automatically switches to the active HDMI signal, so I rarely need to press the select button. Uses a nifty little Pericom HDMI switch chip.
This looks like the Amazon UK version: http://www.amazon.co.uk/Proxima-Switche ... B0063M4E6A
God
Re: DVI Splitter?
Sat Jul 28, 2012 6:27 am
Cjeers john but I need a DVI Switch rather than an HDMI switch.
Wendo
Re: DVI Splitter?
Sun Jul 29, 2012 8:03 pm
DVI and HDMI are pin compatible, price in the cost of as many adapters as you will need (since the pi is HDMI) and see what comes out cheaper
God
Re: DVI Splitter?
Sun Jul 29, 2012 11:07 pm
Guess I don't understand.. my monitor is dvi not hmdi.....My PC is dvi not hdmi. #why wouldI choose an hdmi switch?
GreatBigBadger
Re: DVI Splitter?
Wed Aug 01, 2012 11:59 am
You wouldn't. Go DVI to DVI and have just one HDMI to DVI adapter for the Pi. The switch you found is the cheapest I've seen. Shame there isn't an auto-detect switch at a reasonable price, though.
God
Re: DVI Splitter?
Sat Aug 04, 2012 10:44 pm
For those who might be interested it arrived and I can confirm the DVI switch works well :)
lucyamelia123
Re: DVI Splitter?
Wed Nov 21, 2012 5:26 pm
What you need is a DVI Switch. DVI is digital and low quality products will only give you issues. I would recommend checking Part # DVI-WR-2P.
God
Re: DVI Splitter?
Wed Nov 21, 2012 6:49 pm
As my last post... I have one and it works well...
