myzinsky
Test Card Generator
Fri Jul 27, 2012 10:21 pm
For amateur radio ATV (Amateur television) I want to create a test card generator with the raspberrypi.
It should not be a problem to do that with a linux distri and an high resolution png of the testcard.
like this: http://www.napierjames.com/index_files/image002.png
But I want to integrate the raspberry in my selfbuild ATV transmitter, by using the composite video. And after powering that on the test card should be available after 2-3 seconds.
Is it should be possible to skip all the operating system stuff and integrate that in a native c++ programm? Or is it nearly impossible to controll the graphic unit without linux?
jbeale
Re: Test Card Generator
Fri Jul 27, 2012 10:57 pm
there is already a Linux-free "bare metal" example that can display bitmap images, search for DexOS, for example:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=7004
http://www.dex-os.com/DexBasic/DexBasic.htm
http://www.dex-os.com/DexBasic/Lesson1.htm <- example includes loading a BMP bitmap image as a background screen, + text
I think the image resolution of the DexOS platform is currently fixed at 800x600 pixels, but I'm not sure what the true bandwidth of the R-Pi's analog video output is.
myzinsky
Fri Jul 27, 2012 11:19 pm
That is really nice! How long is the booting time?
DexOS
Sun Jul 29, 2012 3:49 pm
Very nice :) .
Glad you found DexBasic useful.
Batteries not included, Some assembly required.
bennybubble
Fri Mar 01, 2013 9:41 pm
Here my version of the ATV test pattern generator : http://tinyurl.com/asue3xu using Python as the programming language.
-ben
