fopetesl
Yesterday it ran. Today "permission denied" even as root
Tue Nov 24, 2015 11:36 am
SPI_check.c
gcc -Wall -c -o SPIck SPI_Check.c -l bcm2835
No errors.
Same yesterday except yesterday it ran. No code change.
Today ./SPIck "permission denied" even as pi user, sudo or as root.
However. If I
gcc SPI_Check.c -l bcm2835
./a.out
I get no errors and it runs :)
So If I look at mode I see that a.out is executable but SPIck isn't.
So it's my gcc switches?
topguy
Re: Yesterday it ran. Today "permission denied" even as root
Tue Nov 24, 2015 11:38 am
An if you do:
chmod u+x SPIck
to make it executable ?
fopetesl
Tue Nov 24, 2015 12:04 pm
Did that and chown'd.
Still permission denied.
Now I cannot alter or delete the file, says cannot be found :(
RaTTuS
Contact: Twitter YouTube
Tue Nov 24, 2015 12:23 pm
ls -la
Covfefe
SteveSpencer
Tue Nov 24, 2015 12:28 pm
There are a number of possible avenues to explore.
First, unless you alter your PATH to include the current folder, you have to prefix the executable with ./, such as
./SPIck
Secondly, in the first version of your compile command line, you use both -c and -o. This leaves you with an unlinked object file (that is, ld has not been run) named SPIck.
Remove the -c flag and retry.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
fopetesl
Wed Nov 25, 2015 9:19 am
SteveSpencer wrote:There are a number of possible avenues to explore.
./SPIck
Did that. See original post, please.
SteveSpencer wrote:Secondly, in the first version of your compile command line, you use both -c and -o. This leaves you with an unlinked object file (that is, ld has not been run) named SPIck.
Got it! Sorted :) Thank you.
Return to “C/C++”
