JackDooner
Can't SSH Rasp Pi remotely?
Sat Nov 21, 2015 9:15 pm
Hi, I have 2 Raspberry Pi's, both connected via Ethernet with static IP addressed.
I've assigned custom SSH ports for both. (2201 & 2202)
On my first Pi, I have no issues. I can SSH inside or outside my network. Perfect.
But on the other, I have issues from outside my network.
Everything is set up the exact same way (Port Forwarding etc...) and I have extensive experience in networking, so I know what I am doing. How ever I am left scratching my head.
Can anyone suggest further troubleshooting?
From the problematic Pi, I have full internet access. I can ping everything with no problems.
Thanks in advance.
sprinkmeier
Re: Can't SSH Rasp Pi remotely?
Sun Nov 22, 2015 3:57 am
Run tcpdump on both Pis and observe what happens when you try to connect (i.e. do the packets make it as far as the Pi, do they have a funny address? does the Pi know how to route replies?)
ripat
Sun Nov 22, 2015 7:59 am
Check if sshd is running and listening on the right port:
$ sudo netstat -tlpn
Check the log. Raise the log level of the second pi ssd server to DEBUG or DEBUG2. Server side /etc/ssh/sshd_config:
# Logging
SyslogFacility AUTH
LogLevel DEBUG2
restart sshd:
$ sudo  /etc/init.d/ssh restart (or reload)
From the client side, login with the highest verbose available.
$ ssh -vvv <target_address>
Using Linux command line usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
