HerNewTool
Waterproof Touch Screen
Sat Nov 21, 2015 12:47 pm
I've tried to google it.
I need a waterproof touch screen display, for a project i'm currently in the planning stages for.
Do you guys know of any?
W. H. Heydt
Re: Waterproof Touch Screen
Sat Nov 21, 2015 5:18 pm
I don't specifically know of any, but I would point out that the RPF 7" display has a glass front that, if sealed to an otherwise waterproof container (say, with a bead of silicone sealant all the way around) would probably fit your need. I don't think putting it under pressure would be a good idea, though, if that is what you intend to do.
HerNewTool
Sat Nov 21, 2015 6:15 pm
No pressure, just the occasional rain and below freezing temps. Wanting to put a Pi with a touch screen on my motorcycle. Run bluetooth USB engine diagnostics, thumb drive music with speakers, and possibly a GPS...
Aydan
Wed Nov 25, 2015 1:37 pm
Capacitive touch screens often have a problem with water on the surface, meaning the touch recognition gets screwed up.
e.g. the capacitive touch pad of my laptop works really badly when used with a wet finger tip that makes a wet trace.
Might not be well suited for a motorcycle. Or at least you should have a secondary input using keys.
Regards
Aydan
karlkiste
Mon Dec 07, 2015 8:52 am
For this special case I'd recommend to look for a resistive touchscreen. It has a double plastic foil on the surface which senses applied pressure. While in many cases capacitive touchscreens are preferable, resistive ones work even when the surface is wet, and they even work when wearing thick gloves.
Greets,
Kiste
Boldric
Tue May 22, 2018 8:49 pm
Hello HerNewTool
I was wondering if your motorcycle project has advanced any. I am also thinking of creating screen for my custom bmw k100, and was wondering if you hade any pointers. i was thinking of going the route of using an arduino to pick up information, and using a rasberry pi to display
Regards,
Boldric
jackcanon
Sun Jul 29, 2018 8:45 pm
I'm also working on a touchscreen display for my motorcycle, a 2016 Suzuki Vstrom 650CC.
I'm trying to get Android Auto or Open Auto running on mine. I'd love to be able to print a low profile case for the pi plus display and mount it above the instrument cluster, or maybe somewhere else, depending on the profile. Any suggestions for a water-tight housing? My bike splits time between living outside and living in the garage.
przemof
Sat Dec 08, 2018 6:30 pm
Anyone actually uses a touchscreen in wet/cold conditions? I'll need one for a bicycle computer.
jcarter
Fri Jan 11, 2019 6:27 am
I'm also building a motorcycle computer using pi and python. I would love to share notes with anyone about this project.
przemof
Fri Jan 11, 2019 9:57 am
I'll be switching main user input to rotary encoder push button. We should start a new thread in a different part of he forum.
