I'm trying to install Apache, PHP, etc. on a Raspberry Pi 2 Model B.
I've started with a clean install of Jessie, expanded the partition and updated okay but on apt-get upgrade it gets to the following line and hangs up, the only option is pulling the plug.
Unpacking libreoffice-common (1:4.3.3-2+rpi2) over (1:4.3.3-2+rpi1)
I've tried 3 times with a fresh SD card, on the third attempt I used dist-upgrade after reading something on the web but still the same problem.
Any ideas?
Dave.
edit - tried a different SD card but same problem.
