mousematt
OSMC on Official Raspberry Pi Touchscreen
Thu Nov 19, 2015 10:35 am
Hello
Last night I set up my touch screen using Raspbian. I already had installed OSMC onto my SD card but now when I boot up it does not give me the option to switch OS like it did when I was connected to the HDMI. Is this normal?
I can't seem to find anywhere about how to switch OS once the screen is installed.
Can I launch OSMC from the command line in Raspbian and the touch screen work?
Not great when it comes to the programming so a step my step would be great.
Any advice welcome. Thank you in advance.
Re: OSMC on Official Raspberry Pi Touchscreen
Thu Nov 19, 2015 11:12 am
mousematt wrote:Hello
Raspbian and OSMC are 2 seperate Operating Systems.
Did you use NOOBS to install the Operating Systems ??
mousematt
Thu Nov 19, 2015 11:19 am
I did use NOOBS to install both onto the SD card.
Before I installed the screen when the system booted it would take me to a pop up screen where I could choose Raspbian or OSMC. This is no longer happening with the screen attached.
Thu Nov 19, 2015 11:52 am
mousematt wrote:I did use NOOBS to install both onto the SD card.
It is a NOOBS issue
viewtopic.php?f=63&t=120332
mousematt
Fri Nov 20, 2015 11:29 am
It is a NOOBS issue
Thanks fruitoftheloom. Issue was not with NOOBS but with the way I was using the screen. Sorted now but thanks for your help.
