careyjames
boot stuck at "random: nonblocking pool is initiated"
Mon Nov 16, 2015 10:46 pm
Stuck on booting up at "random: nonblocking pool is initiated" after fresh install...
Raspberry Pi 2 kali linux 2.0 with encrypted luks and early dropbear ssh
I did the encypted install with dropbear ssh kali 2
# https://www.offensive-security.com/k...sk-encryption/
#this line is in the cmdline.txt
dwc_otg.fiq_fix_enable=2 console=tty1 console=tty1 root=/dev/mapper/crypt_sdcard cryptdevice=/dev/mmcblk0p2:crypt_sdcard rootfstype=ext4 rootwait rootflags=noload
#I wonder if the "rootwait & rootflags=noload" really needs to be there at the end?????
#I also noticed that my config.txt is blank also when i open it...
#I wonder if in this step:
echo initramfs initramfs.gz 0x00f00000 & /boot/config.txt
#was anything supposed to make it into the config.txt file?
rpdom
Re: boot stuck at "random: nonblocking pool is initiated"
Tue Nov 17, 2015 6:44 am
Almost certainly that line was supposed to be something like
echo initramfs initramfs.gz 0x00f00000 >> /boot/config.txt
which will add "initramfs initramfs.gz 0x00f00000" to the end of the config.txt file.
Without that line the bootloader won't know to load the initial ram filesystem containing the code needed to access your encrypted file system. Try adding that line.
careyjames
Tue Nov 17, 2015 2:40 pm
so some show a ">>" and on the blog page they show a "&" and I've also seen ">"
so which is correct thing for in-between the 0x00f00000 "?" /boot/config.txt
fruit-uk
Tue Nov 17, 2015 3:31 pm
The one that works :)
careyjames
Tue Nov 17, 2015 3:40 pm
the one what? are you saying there should be one ">" ?
careyjames
Tue Nov 17, 2015 3:41 pm
#so this is the EXACT command to send that text into config.txt????
echo initramfs initramfs.gz 0x00f00000 > /boot/config.tx
ShiftPlusOne
Tue Nov 17, 2015 3:46 pm
careyjames wrote:so this is the EXACT command to send that text into config.txt????
rpdom wrote: echo initramfs initramfs.gz 0x00f00000 >> /boot/config.txt
It's worth getting to grips with the linux shell so that you understand what >>, > and & are.
https://www.raspberrypi.org/magpi-issue ... ash_v1.pdf
Tue Nov 17, 2015 3:52 pm
& means run in the background
> means overwrite (truncate)
>> means append
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Joe Schmoe
Tue Nov 17, 2015 3:56 pm
I'm surprised that no one has "strongly suggested" (as is the custom around here) that OP (or anyone else) should really not be using things like "echo" and redirection to edit the boot configuration files.
Surely, using a regular editor is much more likely to work and much more likely to make sense - that is, you can see what you are doing and are able to adjust accordingly if things aren't as you expect.
The editor more commonly recommended around here is something called "nano", but I see no value in using that. If you want GUI, you should use "leafpad".
fruit-uk
Tue Nov 17, 2015 4:39 pm
Joe Schmoe wrote:I'm surprised that no one has "strongly suggested" (as is the custom around here) that OP (or anyone else) should really not be using things like "echo" and redirection to edit the boot configuration files
Read the OP, he's following a script and asked for advice, that's hardly other posters suggesting he uses those commands
Joe Schmoe
Tue Nov 17, 2015 4:50 pm
Irrelevant.
It is standard on these support boards/forums that if someone is doing something wrong, we chime in and tell them to do it an entirely different way. Or not to do it at all (see any/all items about running Windows on the Pi; they all get an immediate response from Dougie telling them something about lawn mowers and trucks, er, lorries).
careyjames
Tue Nov 17, 2015 9:11 pm
ok so, i went thru with your help and modified a few things...
here is my list of commands/actions... that i changed from their tutorial here:
https://www.offensive-security.com/kali ... ncryption/
mkdir -p /mnt/chroot/boot
mount /dev/mmcblk0p2 /mnt/chroot/
mount /dev/mmcblk0p1 /mnt/chroot/boot/
mount -t proc none /mnt/chroot/proc
mount -t sysfs none /mnt/chroot/sys
mount -o bind /dev /mnt/chroot/dev
mount -o bind /dev/pts /mnt/chroot/dev/pts
cp /usr/bin/qemu-arm-static /mnt/chroot/usr/bin/
LANG=C chroot /mnt/chroot/
mkinitramfs -o /boot/initramfs.gz 3.18.16-v7
update-rc.d ssh enable
passwd
nano /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMAO,115200 console=tty1 elevator=deadline root=/dev/mapper/crypt_sdcard cryptdevice=/dev/mmcblk0p2:crypt_sdcard rootfstype=ext4 rootwait
nano /boot/config.txt
cat /etc/initramfs-tools/root/.ssh/id_rsa
nano key
nano /etc/initramfs-tools/root/.ssh/authorized_keys
command="/scripts/local-top/cryptroot && kill -9 `ps | grep -m 1 'cryptroot' | cut -d ' ' -f 3`"
nano /etc/fstab
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mapper/crypt_sdcard / ext4 defaults,noatime 0 1
/dev/mmcblk0p3 swap swap defaults 0 0
nano /etc/crypttab
crypt_sdcard /dev/mmcblk0p2 none luks
nano /usr/share/initramfs-tools/scripts/init-premount/dropbear
echo "Waiting 5 seconds for USB to wake"
sleep 5
exit
umount /mnt/chroot/boot
umount /mnt/chroot/sys
umount /mnt/chroot/proc
mkdir -p /mnt/backup
rsync -avh /mnt/chroot/* /mnt/backup/
umount /mnt/chroot/dev/pts
umount /mnt/chroot
echo -e "d\n2\nw" | fdisk /dev/mmcblk0
echo -e "n\np\n2\n\n\nw" | fdisk /dev/mmcblk0
fdisk -l /dev/mmcblk0
cryptsetup -v -y --cipher aes-cbc-essiv:sha256 --key-size 256 luksFormat /dev/mmcblk0p2
cryptsetup -v luksOpen /dev/mmcblk0p2 crypt_sdcard
mkfs.ext4 /dev/mapper/crypt_sdcard
mkdir -p /mnt/encrypted
mount /dev/mapper/crypt_sdcard /mnt/encrypted/
rsync -avh /mnt/backup/* /mnt/encrypted/
umount /mnt/encrypted/
rm -rf /mnt/backup
sync
cryptsetup luksClose /dev/mapper/crypt_sdcard
cryptsetup luksAddNuke /dev/mmcblk0p2
********and it booted in the pi but got caught in a loop that said:
/sbin/cryptsetup: not found
cryptsetup: cryptsetup failed, bad password or options?
/scripts/local-top/cryptroot: /scripts/local-top/cryptroot: line 1: line 1: /lib/crypt/askpass: not found/sbin/cryptsetup: not found
over and over and over again until it stopped and said:
gave up waiting for root device common problems:
boot args (cat /proc/cmdline)
missing modules (cat /proc/modules; Is /dev)
ALERT! /dev/mapper/crypt_sdcard does not exist
dropping to a shell
so it never asked me for a password... to unlock luks
careyjames
Tue Nov 17, 2015 9:35 pm
this line that they as us to add before the ssh key:
i notice on the sd there is no /scripts/local-top/ folder...
noahspurrier
Thu Dec 06, 2018 2:08 pm
Removing
from cmdline.txt fixed it for me. Setting it to 2 doesn't make sense. Yes, anything not zero is true, but setting it to 2 makes it appear that this was a mistake. At any rate it fixed it for me.
Return to “Debian”
