I've tried a handful of things including fstab with various settings (sync, auto, exec, and a bunch more), usbmount and bash/python scripting but I don't get any reliable results. It works smooth when powering on, but the project I'm working on should allow unmounting, taking a usb out, popping a different stick in, OS/application/script/whatever mounts the flash drive and run.
So far, this has failed to give me any insights as to how I should go about doing this. Too much hit/miss to say one thing definitely does or doesn't work. Somehow the system, at some point, decides "let's mount the flash drive as read only this time! That'll be fun!" or "Meh, I'm gonna say it's mounted but let the ls command come up empty."
I do have one more idea I wanna test which is using a ram-disk type set-up and mount the USB in the ram-disk. I don't know if this is possible or even a good idea. But before I dive into yet another two day event of Google, outdated tutorials, more Google and 100s of cups of coffee.. Has anyone else tried or know how to mount a read/write USB hdd/flash disk within a read-only OS? :3
