Hi Topguy,
I am a Linux newbie, but I want to learn.
My PI has a SD Drive with OS, and the USB Disk drive.
In the 'create mount' screen, in the Windows NT FileSystem , I choose 'Other device' , and then '/dev/sda1' , and it seemed to work! ( I am guessing that sda1 is my usb drive based on the result of running dmesg after plugging in the usb drive:
- [ 115.208646] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 115.309746] usb 1-1.4: New USB device found, idVendor=0bc2, idProduct=5071
[ 115.309776] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 115.309794] usb 1-1.4: Product: FA GoFlex Desk
[ 115.309810] usb 1-1.4: Manufacturer: Seagate
[ 115.309826] usb 1-1.4: SerialNumber: NA0J6JG0
[ 115.311755] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 115.312712] scsi host0: usb-storage 1-1.4:1.0
[ 116.309476] scsi 0:0:0:0: Direct-Access Seagate FA GoFlex Desk 0155 PQ: 0 ANSI: 4
[ 116.313067] sd 0:0:0:0: [sda] 3907029167 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 116.313635] sd 0:0:0:0: [sda] Write Protect is off
[ 116.313663] sd 0:0:0:0: [sda] Mode Sense: 1c 00 00 00
[ 116.314331] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 116.335763] sda: sda1
[ 116.339310] sd 0:0:0:0: [sda] Attached SCSI disk
[ 116.348358] sd 0:0:0:0: Attached scsi generic sg0 type 0
