JooPo
Python + PiCamera + Gstreamer
Mon Nov 16, 2015 12:14 pm
I'm trying to stream video from Raspis camera to my computer via udp. I'm using PiCamera and Gstreamer on python, so I can control them both directly and easily from the code. The problem is, I can't pipe the stream from the PiCamera to gstreamer like in the command prompt. The problematic part of my code is here:
stream = io.BytesIO()
camera = picamera.PiCamera()
camera.start_recording(stream, format='h264', quality=23)
pipeline = Gst.Pipeline()
src = Gst.ElementFactory.make("fdsrc", None)
src.set_property("fd", stream)
pipeline.add(src)
The pipe works from the first ElementFactory, I've tried it on command prompt. The camera works also. The question is, how can I stream the video from PiCamera in a way, that I can read it with Gstreamer and stream is forward?
-rst-
Re: Python + PiCamera + Gstreamer
Mon Nov 16, 2015 3:39 pm
No experience with PiCamera or Gstreamer unfortunately. As a last resort you could maybe look at running your command prompt incantations using subprocess?
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
Return to “Python”
