lilzz
A vector of bunch of constant 1's
Sun Nov 15, 2015 1:21 am
1)BasedBitVector<1> locked;
what's the use of this one? what purpose?
2) BasedVector<int, 1> gate
why two types inside <>? it's a vector of int and constant 1's?
3) std::vector<std::vector<int>> related_tiles;
is that of 2D array of ints?
AndyD
Re: A vector of bunch of constant 1's
Sun Nov 15, 2015 1:50 am
lilzz wrote:1)BasedBitVector<1> locked;
Where is BasedBitVector from? How do we know what the template argument means without knowing where the code is from.
lilzz wrote:2) BasedVector<int, 1> gate
Same answer as question one.
lilzz wrote:3) std::vector<std::vector<int>> related_tiles;
Essentially yes you could consider it that way. It is a vector of vectors that hold an int.
lilzz
Sun Nov 15, 2015 2:30 am
#ifndef PNR_BITVECTOR_HH
#define PNR_BITVECTOR_HH
#include <vector>
#include <cstddef>
#include <cstdint>
#include <cassert>
template<size_t B>
class BasedBitVector
  int n;
  std::vector<uint64_t> v;
public:
  class BitRef
    std::vector<uint64_t> &v;
    size_t i;
  public:
    BitRef (std::vector<uint64_t> &v_, size_t i_)
      : v(v_), i(i_)
    BitRef &operator=(bool x)
      size_t w = (i - B) / 64,
        b = (i - B) & 63;
      uint64_t m = ((uint64_t)1 << b);
      assert(w < v.size());
      if (x)
        v[w] |= m;
      else
        v[w] &= ~m;
      return *this;
    operator bool() const
        b = (i - B) & 63;
      return v[w] & m;
  BasedBitVector() {}
  BasedBitVector(size_t n_)
    : n(n_), v((n + 63) / 64, 0)
  BasedBitVector(size_t n_, uint64_t init)
    v[0] = init;
  void resize(size_t n_)
    n = n_;
    v.resize((n + 63) / 64, 0);
  void zero()
    std::fill(v.begin(), v.end(), 0);
  size_t size() const { return n; }
  bool operator[](size_t i) const
    assert(i >= B && i < n + B);
      b = (i - B) & 63;
    return v[w] & m;
  BitRef operator[](size_t i)
    return BitRef(v, i);
using BitVector = BasedBitVector<0>;
using BitVector1 = BasedBitVector<1>;
#endif
here's the definition of Baedbitvector. i am lost as what this does. what's with 64, 63?
      b = (i - B) & 63;
    return v[w] & m;
what it trying to do?
ame
Sun Nov 15, 2015 2:38 am
I guess you never bought that book about programming.
What's up with the 64 and 63? Well, one is probably doing a right shift by 6 bits. The other is masking the lower 6 bits (and discarding the higher bits).
As usual, you cannot expect to understand these things without studying, or without looking at their context.
AndyD
Sun Nov 15, 2015 3:05 am
It appears that BasedVector and BaseBitVector are to allow you to have base 1 vectors (or other bases if you so wish). That is so that locked[1] refers to the first bit in the bit vector rather than locked[0].
So BasedVector allows you to have a vector of a base other than zero. It appear the code only uses base one. So the int is the type in the vector and the value '1' is the base of the vector. So gate[1] refers to the first int in the vector, rather than in a standard vector gate[0].
AndyD
Sun Nov 15, 2015 3:27 am
      b = (i - B) & 63;
    return v[w] & m;
The bit vector is being stored as a vector of 64 bit ints. So if your vector contains less than 64 bits, it is stored as one 64 bit int.
B is the base of the vector (as described above).
w is the index into the member std::vector that holds the 64 bit integers. Divide by 64 as that is the number of bits held in each 64 bit integer. Subtract B from i to get rid of the base being used.
b = (i - B) & 63
b is the bit number of bit to access in the 64 bit integer of interest. The value 63 is a mask, so that b is in the range [0,63].
It is the remainder from the above division. It could have been written "b = (i - B) % 64"
m is a mask to access the b'th bit in the 64 bit integer of interest.
return v[w] & m;
Finally the w'th 64 bit integer from the vector of integers used to implement the bit array is retrieved. Bitwise and is used to isolate the bit of interest from the retrieved 64 bit integer. The bool type is either true or false. A non-zero integer value becomes true, a zero value becomes false. If the bit is a 1, then true is returned. if the bit is a 0, the false is returned.
lilzz
Sun Nov 15, 2015 5:33 am
@andyD , your explanation is very cool. Thx
Return to “C/C++”
