JonnyAlpha
Raspberry Pi Certified Educator
Playing a beep using Python
Sat Nov 14, 2015 10:40 am
Hi;
I have been asked a question that I cant find the answer to.
Can you / how do you play a sound using python, but not from a sound file i.e. can you use Python to generate a sound?
Thanks in advance
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
JonnyAlpha
Re: Playing a beep using Python
Sat Nov 14, 2015 10:54 am
Sorry the gentleman is trying to use print "\a"
Laurens-wuyts
Sat Nov 14, 2015 11:15 am
You can try:
print('\a')
Which is working in Windows 10. ;)
I'm not sure if it produces a sound on a RPi. :?
Laurens
JonnyAlpha
Sun Nov 15, 2015 11:41 am
Thanks Laurens I think that is the problem, this line of code does not result in a sound from the Pi.
Laurens-wuyts
Sun Nov 15, 2015 11:47 am
You can try what's mentioned here. ;)
Laurens
Return to “Python”
