boyoh wrote:I agree with Mahjongg , you need to learn some basic electronics before you go any further
I will start by asking how old you are, this gives us some Idea of how to speak to you with respect.
A list of things you will need for basic electronic circuit building , 0 /12v/ 3A adjustable power supply
A breadboard ,book on starter circuits to build, Leds/ resistors /diodes / transistors ( 2n2222 ) are very us full.
You will need a multimeter , a cheap one will do,
Learn Ohms Law, and how to use It.
The strength of a current (amps) is directly proportional to the Pressure ( volts ) between two points.
But is inversely proportional to It's Resistance (Ohms)
Don't use the Pi as your breadboard,, Put your Pi back in the box, until you know how to interface with it.
I'm being blunt , but building circuits is the only way to ,learn electronics . There is no Magic Formula.
Okay then, I am doing some research of my own at the time. UC Berkley has lots of lectures posted on their youtube account, and the guy teaching the class is very entertaining so it makes it much more easier.
here is the first lecture
https://www.youtube.com/watch?v=MpBwvCq6vWM
I have several trasistors (NPN and PNP, mostly NPN by like over 100), Triodes and Pentodes, resistors of varying values, two multimeters (the second came from a friend, i didn't want to say no), some LEDs, a motor from a shark cleaner (for motor control experiments), 20 small breadboards that wer being sold for arduinos, two full sized breadboards, a breakout ribbon and circuit set for both model B and model B+, and finally some hookup wire.
The textbooks that I have been reading are Lessons in Electric Circuits and there are some open textbooks focussing on electrical engineering and circuits which I have to check out. I have some cheat sheets I made back in highschool (It's obviously been a while, I started to lose all the information once I started going more into computer science). I am also 24 years old.
Here's lessons in electric circuits, the books I have been reading since highschool but then abruptly stopped after graduating and then I had to focus on many other things. oh the process of becoming an adult really deters you from having any hobbies.
https://www.ibiblio.org/kuphaldt/electricCircuits/
