Here, by the way, is the code I'm using...
Server:
import pyaudio, sys, socket
port = 5000
chunk = 512
FORMAT = pyaudio.paInt16
CHANNELS = 1
RATE = 44100
p = pyaudio.PyAudio()
stream = p.open(format = FORMAT, channels = CHANNELS, rate = RATE, input = True, output = True, frames_per_buffer = chunk)
server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM) # create the socket
server_socket.bind(('', port)) # listen on port 5000
server_socket.listen(5) # queue max 5 connections
client_socket, address = server_socket.accept()
print "Your IP address is: ", socket.gethostbyname(socket.gethostname())
print "Server Waiting for client on port ", port
while True:
# test string
#data = bytearray('DEADBEEF'.decode('hex'))
#client_socket.sendall(data)
try:
client_socket.sendall(stream.read(chunk))
except IOError,e:
if e[1] == pyaudio.paInputOverflowed:
print e
x = '\x00'*16*256*2 #value*format*chunk*nb_channels
stream.stop_stream()
stream.close()
socket.close()
p.terminate()
Client:
port = 5000
ip = "change to your ip address"
chunk = 512
CHANNELS = 1
RATE = 44100
stream = p.open(format = FORMAT, channels = CHANNELS, rate = RATE, input = True,output = True, frames_per_buffer = chunk)
#Create a socket connection for connecting to the server:
client_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
client_socket.connect((ip, port))
while True:
#Recieve data from the server:
data = client_socket.recv(1024)
stream.write(data,chunk)
#print data
socket.close()
