I want to use a raspberrt as a thinclient to connect as rdp to win server.
1. Wich pi is best for this? Because the pi2 have connection of 10/100.
2. If i install wondoes 10 on the pi it will work good?
Thanks.
apt-get is for Debian, this post is in the Windows 10 IoT Core ForumRST8 wrote:If you want to use the Pi as a client, then Remmina will work for RDP to a windows server, although performance will vary depending on the type of graphics being displayed. I don't think it's installed by default, so you'll need to install it using apt-get install.
There's also the thin client project:
http://rpitc.blogspot.co.uk/
Joe
Right, but OP wants RDP. So, either the original post is in the wrong forum, or we have to offer a solution which doesn't use Winiot.fruitoftheloom wrote:apt-get is for Debian, this post is in the Windows 10 IoT Core ForumRST8 wrote:If you want to use the Pi as a client, then Remmina will work for RDP to a windows server, although performance will vary depending on the type of graphics being displayed. I don't think it's installed by default, so you'll need to install it using apt-get install.
Joe
Well, IoT forum or not, the OP didn't specifically request that they wanted to use the IoT build (and I can't think why you would want to for this scenario), just would it work, which as people have pointed out, won't.ame wrote:Right, but OP wants RDP. So, either the original post is in the wrong forum, or we have to offer a solution which doesn't use Winiot.fruitoftheloom wrote:apt-get is for Debian, this post is in the Windows 10 IoT Core ForumRST8 wrote:If you want to use the Pi as a client, then Remmina will work for RDP to a windows server, although performance will vary depending on the type of graphics being displayed. I don't think it's installed by default, so you'll need to install it using apt-get install.
Joe
