New Blog post about setting up your Pi with ddclient and a dynamic DNS server so you can host your own website from your Pi behind your home router.
http://raspberrypipod.blogspot.co.uk/20 ... erver.html
Dynamic DNS with the Pi
My Raspberry Pi blog with all my latest projects and links to articles
http://raspberrypipod.blogspot.com. +++ Current project: PiPodTricorder - lots of sensors, lots of mini-displays, breadboarding, bit of programming.
Re: Dynamic DNS with the Pi
I've used ddclient with success. The only problem I found is that it used too much precious memory as it uses 'sleep' between scheduled ip checks. What I've done instead is use a python script that I can put in the cron to check checkip.dyndns.org at very regular intervals and update my DNS provider (zoneedit in this case). http://zoneclient.sourceforge.net/
I'm sure there must be other generic scripts out there that can do the same thing for other DNS providers.
Now _that's_ creative thinking. Thanks! Will grab that script when I get home!
If you have a Router supporting DDNS you can setup there, so you avoid installing one more thing on the Pi.
Nr.1 Raspberry Pi Mod.B Rev.2 256Mb Ram (Raspbian)
Raspberry Pi Mod.B Rev.2 512Mb Ram (Maybe i´ll get one)
What are some routers that support this, that you recommend
that will run out of the box?
Here is a similar tutorial for beginners.. from start to finish for the beginners out there:
http://www.administeria.com/raspberry-p ... -raspbian/
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
You're replying to a post that's 1 year and 9 months old. So no surprises there.Bosse_B wrote:The link above to the tutorial is broken....
What dynamic DNS service are you trying to use/abuse with your RPi?
