girl71
How set certain time for digitalwrite
Mon Nov 02, 2015 4:48 am
I'm new in programming with wiring pi :oops: :oops: and I want to set time for digital write with get time(NULL) after get key then stop writing (after certain time or with e key)and goto first of loop , my program doesn't work ,what is the problem?? :roll: :roll: I try with millis() but after 5sec val doesn't change auto to LOW until I press d or a val be LOW and goto first of the loop,Could this be another solution?
void digital::loop(int motor_pin_1, int motor_pin_2, char key) {
time_t now,after;
	time_t second=10;
	printf("press 'd (<--open-->)' or 'a (-->close<--)' key OR 'e' to stop  and  change  mode:\n");
	do {
		key = getchar();
		now = time(NULL);
		after= now+ second;
		if (key == 'd') {
			printf("<--open-->\n");
			digitalWrite(motor_pin_1, HIGH);
			digitalWrite(motor_pin_2, LOW);
		else if (key == 'a') {
			printf("-->close<--\n");
			digitalWrite(motor_pin_2, HIGH);
			 digitalWrite(motor_pin_1, LOW);
			//delayMicroseconds(200);
			//	digitalWrite(motor_pin_1, LOW);
			//	digitalWrite(motor_pin_2, LOW);
	} while (key != 'e' || now<after);
	unsigned long  startTime;
do{
		key = getchar();
		 startTime = millis();
		if (key == 'd') {
			else if (key == 'e') {
break;
}while (millis() - startTime <= 5000);
joan
Re: How set certain time for digitalwrite
Mon Nov 02, 2015 11:45 am
The getchar function blocks until a carriage return is pressed.
girl71
Mon Nov 02, 2015 5:10 pm
scanf, is the same does??
joan
Mon Nov 02, 2015 5:20 pm
girl71 wrote:scanf, is the same does??
Yes, scanf does the same.
You will need to do raw IO. See the following example.
Call the file term.c
gcc term.c
./a.out
Press esc to finish.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/select.h>
#include <termios.h>
struct termios orig_termios;
void reset_terminal_mode()
    tcsetattr(0, TCSANOW, &orig_termios);
void set_conio_terminal_mode()
    struct termios new_termios;
    /* take two copies - one for now, one for later */
    tcgetattr(0, &orig_termios);
    memcpy(&new_termios, &orig_termios, sizeof(new_termios));
    /* register cleanup handler, and set the new terminal mode */
    atexit(reset_terminal_mode);
    cfmakeraw(&new_termios);
    tcsetattr(0, TCSANOW, &new_termios);
int dataRdy(int fd)
    struct timeval tv = { 0L, 0L };
    fd_set fds;
    FD_ZERO(&fds);
    FD_SET(fd, &fds);
    return select(fd+1, &fds, NULL, NULL, &tv);
int getch()
    int r;
    unsigned char c;
    if ((r = read(0, &c, sizeof(c))) < 0)
        return r;
    else
        return c;
int main(int argc, char *argv[])
   int c;
   set_conio_terminal_mode();
   while(1)
      if (dataRdy(0))
         c = getch();
         printf("%c (%d)\n", c, c);
         if (c == 27) break; /* esc key */
      usleep(1000);
   reset_terminal_mode();
girl71
Mon Nov 02, 2015 7:38 pm
your mean change 'd' to '100' of ascii value??If i change it the problem still exist :? :?
joan
Mon Nov 02, 2015 9:13 pm
girl71 wrote:your mean change 'd' to '100' of ascii value??If i change it the problem still exist :? :?
No. I mean that you can not use getchar or scanf to do what you want. You must use non-blocking I/O as in the example I gave.
girl71
Tue Nov 03, 2015 5:59 am
Thank you but,If I use part of your code, for stop program still need press key.......
 int digital:: getch()
        int r;
        unsigned char c;
            return r;
        else
            return c;
do{
		key = getch();
		if (key == 'd') {
break;
	} while (millis() - startTime <= 5000);
joan
Tue Nov 03, 2015 8:35 am
You need all the code (apart from main) to put the system into non-blocking I/O. You can't pick and choose which parts might look relevant.
In your main you need to make the calls to set_conio_terminal_mode() at the start, reset_terminal_mode() at the end, and check dataRdy(0) before the getch().
davenull
Tue Nov 03, 2015 9:24 am
hey,
I just was running into this same issue,
now I found this code which is working fine, and even is quite quick:
#include <unistd.h>
#include <fcntl.h>
int kbhit(void)
  struct termios oldt, newt;
  int ch;
  int oldf;
  tcgetattr(STDIN_FILENO, &oldt);
  newt = oldt;
  newt.c_lflag &= ~(ICANON | ECHO);
  tcsetattr(STDIN_FILENO, TCSANOW, &newt);
  oldf = fcntl(STDIN_FILENO, F_GETFL, 0);
  fcntl(STDIN_FILENO, F_SETFL, oldf | O_NONBLOCK);
  ch = getchar();
  tcsetattr(STDIN_FILENO, TCSANOW, &oldt);
  fcntl(STDIN_FILENO, F_SETFL, oldf);
  if(ch != EOF)
    ungetc(ch, stdin);
    return 1;
  return 0;
http://cboard.cprogramming.com/c-progra ... linux.html
HTH!
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
girl71
Tue Nov 03, 2015 10:01 am
oops it's better
girl71
Tue Nov 03, 2015 7:16 pm
joan wrote:You need all the code (apart from main) to put the system into non-blocking I/O. You can't pick and choose which parts might look relevant.
thank you very much for your help , it's work :lol: :lol: :lol: :lol:
girl71
Tue Nov 03, 2015 7:26 pm
@ davenull thank you
Return to “C/C++”
