enzofxxjia
wxpython StaticText Realtime update
Sun Nov 01, 2015 7:31 pm
Hi Guys
I am total beginner in programming. I already start a small project by using raspberry PI connect to the car OBD port and reading the data to the wxpython GUI. The OBD library I was using from http://brendan-w.com/work/python-obd.
By using the instruction above, I could successful print living rpm data in the python shell line by line.
Code is here:
import obd
import time
connection = obd.Async("/dev/rfcomm0") # same constructor as 'obd.OBD()'
cmd = obd.commands.RPM
connection.watch(cmd) # keep track of the RPM
connection.start() # start the async update loop
while(True):
           response_rpm = connection.query(cmd).value
           print(response_rpm) # non-blocking, returns immediately
           time.sleep(0.01)
#obd.debug.console = True
After this, I created the GUI by using wxformbuilder and change to wxpython code. I test the GUI wxpython code in raspberry PI which was no problem. But after add my OBD library code into it and, the whole frame is not working The thing that I want to do is to using the staticText.SetLabel() to display the living data in a while loop. The Code after add OBD library is here
# -*- coding: utf-8 -*-
## Python code generated with wxFormBuilder (version Jun 17 2015)
## http://www.wxformbuilder.org/
## PLEASE DO "NOT" EDIT THIS FILE!
import wx
import obd
import time
## Class MyFrame1
class MyFrame1 ( wx.Frame ):
        def __init__( self, parent,id,title ):
                wx.Frame.__init__ ( self, parent, id = wx.ID_ANY, title = wx.EmptyString, pos = wx.DefaultPosition, size = wx.Size( 480,320 ), style = wx.DEFAULT_FRAME_STYLE|wx.TAB_TRAVERSAL )
                self.SetSizeHintsSz( wx.DefaultSize, wx.Size( 480,320 ) )
                self.SetBackgroundColour( wx.Colour( 0, 0, 0 ) )
                gSizer3 = wx.GridSizer( 3, 3, 0, 0 )
                self.time_adv_staticText = wx.StaticText( self, wx.ID_ANY, u"time_adv", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.time_adv_staticText.Wrap( -1 )
                self.time_adv_staticText.SetFont( wx.Font( wx.NORMAL_FONT.GetPointSize(), 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.time_adv_staticText.SetForegroundColour( wx.Colour( 0, 255, 0 ) )
                gSizer3.Add( self.time_adv_staticText, 0, wx.ALIGN_CENTER, 5 )
                gSizer3.AddSpacer( ( 0, 0), 1, wx.EXPAND, 5 )
                self.MAF_staticText = wx.StaticText( self, wx.ID_ANY, u"MAF", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.MAF_staticText.Wrap( -1 )
                self.MAF_staticText.SetFont( wx.Font( wx.NORMAL_FONT.GetPointSize(), 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.MAF_staticText.SetForegroundColour( wx.Colour( 0, 255, 0 ) )
                gSizer3.Add( self.MAF_staticText, 0, wx.ALIGN_CENTER|wx.ALL, 5 )
                self.SPEED_staticText = wx.StaticText( self, wx.ID_ANY, u"Km/h", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.SPEED_staticText.Wrap( -1 )
                self.SPEED_staticText.SetFont( wx.Font( 20, 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.SPEED_staticText.SetForegroundColour( wx.Colour( 0, 255, 0 ) )
                self.SPEED_staticText.SetBackgroundColour( wx.Colour( 0, 0, 0 ) )
                gSizer3.Add( self.SPEED_staticText, 0, wx.ALIGN_CENTER|wx.ALL|wx.EXPAND, 5 )
                self.Throttle_staticText = wx.StaticText( self, wx.ID_ANY, u"Throttle", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.Throttle_staticText.Wrap( -1 )
                self.Throttle_staticText.SetFont( wx.Font( wx.NORMAL_FONT.GetPointSize(), 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.Throttle_staticText.SetForegroundColour( wx.Colour( 0, 255, 64 ) )
                gSizer3.Add( self.Throttle_staticText, 0, wx.ALIGN_CENTER|wx.ALL, 5 )
                self.RPM_staticText = wx.StaticText( self, wx.ID_ANY, u"RPM", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.RPM_staticText.Wrap( -1 )
                self.RPM_staticText.SetFont( wx.Font( 15, 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.RPM_staticText.SetForegroundColour( wx.Colour( 0, 255, 0 ) )
                gSizer3.Add( self.RPM_staticText, 0, wx.ALIGN_CENTER|wx.ALL|wx.EXPAND, 5 )
                self.Intake_staticText = wx.StaticText( self, wx.ID_ANY, u"Intake", wx.DefaultPosition, wx.DefaultSize, wx.ALIGN_CENTRE )
                self.Intake_staticText.Wrap( -1 )
                self.Intake_staticText.SetFont( wx.Font( wx.NORMAL_FONT.GetPointSize(), 70, 90, 90, False, "@Arial Unicode MS" ) )
                self.Intake_staticText.SetForegroundColour( wx.Colour( 0, 255, 0 ) )
                gSizer3.Add( self.Intake_staticText, 0, wx.ALIGN_CENTER|wx.ALL, 5 )
                self.SetSizer( gSizer3 )
                self.Layout()
                self.Centre( wx.BOTH )
# Every wxWidgets application must have a class derived from wx.App
class MyApp(wx.App):
    # wxWindows calls this method to initialize the application
    def OnInit(self):
        # Create an instance of our customized Frame class
        frame = MyFrame1(None, -1, "")
        frame.Show(True)
        # Tell wxWindows that this is our main window
        self.SetTopWindow(frame)
        #step up OBD connection and get update information
        connection.watch(obd.commands.RPM) # keep track of the RPM
        while(True):
                   r_rpm=connection.query(obd.commands.RPM).value
                   frame.RPM_staticText.SetLabel(str(r_rpm)+'RPM')#frame is who de shenm shen
                   frame.Show(True)
                   time.sleep(0.001)
        # Return a success flag
        return True
app = MyApp(0)     # Create an instance of the application class
app.MainLoop()     # Tell it to start processing events
after running this in the raspberry Pi I only got a gray frame and nothing work
Please help me, I don't know how to pursue further from here
-rst-
Re: wxpython StaticText Realtime update
Fri Nov 13, 2015 3:19 pm
I would assume the OnInit method would need to return for the wx framework to continue with the application - now your code enters the infinite while(True) loop and never returns control to the framework.
Graphical user interfaces and tight loops don't go well together. You would need to look at creating a separate thread for the OBD reading code or maybe the wx framework has somekind of timer object that could be used to periodically read...
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
Return to “Python”
