joan
Python 433MHz wireless fob RX/TX
Fri Oct 30, 2015 11:34 am
I have written a module to capture and transmit 433MHz wireless keyfob codes.
In my limited tests it seems more reliable and much less resource hungry than the other current solutions.
Code also available from http://abyz.co.uk/rpi/pigpio/code/_433_py.zip
#!/usr/bin/env python
# _433.py
# 2015-10-30
# Public Domain
This module provides two classes to use with wireless 433MHz fobs.
The rx class decodes received fob codes. The tx class transmits
fob codes.
import time
import pigpio
class rx():
   A class to read the wireless codes transmitted by 433 MHz
   wireless fobs.
   def __init__(self, pi, gpio, callback=None,
                      min_bits=8, max_bits=32, glitch=150):
      Instantiate with the Pi and the GPIO connected to the wireless
      receiver.
      If specified the callback will be called whenever a new code
      is received.  The callback will be passed the code, the number
      of bits, the length (in us) of the gap, short pulse, and long
      pulse.
      Codes with bit lengths outside the range min_bits to max_bits
      will be ignored.
      A glitch filter will be used to remove edges shorter than
      glitch us long from the wireless stream.  This is intended
      to remove the bulk of radio noise.
      self.pi = pi
      self.gpio = gpio
      self.cb = callback
      self.min_bits = min_bits
      self.max_bits = max_bits
      self.glitch = glitch
      self._in_code = False
      self._edge = 0
      self._code = 0
      self._gap = 0
      self._ready = False
      pi.set_mode(gpio, pigpio.INPUT)
      pi.set_glitch_filter(gpio, glitch)
      self._last_edge_tick = pi.get_current_tick()
      self._cb = pi.callback(gpio, pigpio.EITHER_EDGE, self._cbf)
   def _timings(self, e0, e1):
      Accumulates the short and long pulse length so that an
      average short/long pulse length can be calculated. The
      figures may be used to tune the transimission settings.
      if e0 < e1:
         shorter = e0
         longer = e1
      else:
         shorter = e1
         longer = e0
      if self._bits:
         self._t0 += shorter
         self._t1 += longer
      else:
         self._t0 = shorter
         self._t1 = longer
      self._bits += 1
   def _calibrate(self, e0, e1):
      The first pair of pulses is used as the template for
      subsequent pulses.  They should be one short, one long, not
      necessarily in that order.  The ratio between long and short
      should really be 2 or more.  If less than 1.5 the pulses are
      assumed to be noise.
      self._bits = 0
      self._timings(e0, e1)
      self._bits = 0
      ratio = float(self._t1)/float(self._t0)
      if ratio < 1.5:
      slack0 = int(0.3 * self._t0)
      slack1 = int(0.2 * self._t1)
      self._min_0 = self._t0 - slack0
      self._max_0 = self._t0 + slack0
      self._min_1 = self._t1 - slack1
      self._max_1 = self._t1 + slack1
   def _test_bit(self, e0, e1):
      Returns the bit value represented by the sequence of pulses.
      0: short long
      1: long short
      2: illegal sequence
      if   ( (self._min_0 < e0 < self._max_0) and
             (self._min_1 < e1 < self._max_1) ):
         return 0
      elif ( (self._min_0 < e1 < self._max_0) and
             (self._min_1 < e0 < self._max_1) ):
         return 1
      else:
         return 2
   def _cbf(self, g, l, t):
      Accumulates the code from pairs of short/long pulses.
      The code end is assumed when an edge greater than 5 ms
      is detected.
      edge_len = pigpio.tickDiff(self._last_edge_tick, t)
      self._last_edge_tick = t
      if edge_len > 5000: # 5000 us, 5 ms.
         if self._in_code:
            if self.min_bits <= self._bits <= self.max_bits:
               self._lbits = self._bits
               self._lcode = self._code
               self._lgap = self._gap
               self._lt0 = int(self._t0/self._bits)
               self._lt1 = int(self._t1/self._bits)
               self._ready = True
               if self.cb is not None:
                  self.cb(self._lcode, self._lbits,
                          self._lgap, self._lt0, self._lt1)
         self._in_code = True
         self._gap = edge_len
         self._edge = 0
         self._bits = 0
         self._code = 0
      elif self._in_code:
         if self._edge == 0:
            self._e0 = edge_len
         elif self._edge == 1:
            self._calibrate(self._e0, edge_len)
         if self._edge % 2: # Odd edge.
            bit = self._test_bit(self._even_edge_len, edge_len)
            self._code = self._code << 1
            if bit == 1:
               self._code += 1
            elif bit != 0:
         else: # Even edge.
            self._even_edge_len = edge_len
         self._edge += 1
   def ready(self):
      Returns True if a new code is ready.
      return self._ready
   def code(self):
      Returns the last receieved code.
      self._ready = False
      return self._lcode
   def details(self):
      Returns details of the last receieved code.  The details
      consist of the code, the number of bits, the length (in us)
      of the gap, short pulse, and long pulse.
      self._ready = False
      return self._lcode, self._lbits, self._lgap, self._lt0, self._lt1
   def cancel(self):
      Cancels the wireless code receiver.
      if self._cb is not None:
         self.pi.set_glitch_filter(self.gpio, 0) # Remove glitch filter.
         self._cb.cancel()
         self._cb = None
class tx():
   A class to transmit the wireless codes sent by 433 MHz
   wireless fobs.
   def __init__(self, pi, gpio, repeats=6, bits=24, gap=9000, t0=300, t1=900):
      transmitter.
      The number of repeats (default 6) and bits (default 24) may
      be set.
      The pre-/post-amble gap (default 9000 us), short pulse length
      (default 300 us), and long pulse length (default 900 us) may
      be set.
      self.pi = pi
      self.gpio = gpio
      self.repeats = repeats
      self.bits = bits
      self.gap = gap
      self.t0 = t0
      self.t1 = t1
      self._make_waves()
      pi.set_mode(gpio, pigpio.OUTPUT)
   def _make_waves(self):
      Generates the basic waveforms needed to transmit codes.
      wf = []
      wf.append(pigpio.pulse(1<<self.gpio, 0, self.t0))
      wf.append(pigpio.pulse(0, 1<<self.gpio, self.gap))
      self.pi.wave_add_generic(wf)
      self._amble = self.pi.wave_create()
      wf = []
      wf.append(pigpio.pulse(0, 1<<self.gpio, self.t1))
      self._wid0 = self.pi.wave_create()
      wf = []
      wf.append(pigpio.pulse(1<<self.gpio, 0, self.t1))
      wf.append(pigpio.pulse(0, 1<<self.gpio, self.t0))
      self._wid1 = self.pi.wave_create()
   def set_repeats(self, repeats):
      Set the number of code repeats.
      if 1 < repeats < 100:
   def set_bits(self, bits):
      Set the number of code bits.
      if 5 < bits < 65:
         self.bits = bits
   def set_timings(self, gap, t0, t1):
      Sets the code gap, short pulse, and long pulse length in us.
      self.gap = gap
      self.t0 = t0
      self.t1 = t1
      self.pi.wave_delete(self._amble)
      self.pi.wave_delete(self._wid0)
      self.pi.wave_delete(self._wid1)
      self._make_waves()
   def send(self, code):
      Transmits the code (using the current settings of repeats,
      bits, gap, short, and long pulse length).
      chain = [self._amble, 255, 0]
      bit = (1<<(self.bits-1))
      for i in range(self.bits):
         if code & bit:
            chain += [self._wid1]
         else:
            chain += [self._wid0]
         bit = bit >> 1
      chain += [self._amble, 255, 1, self.repeats, 0]
      self.pi.wave_chain(chain)
      while self.pi.wave_tx_busy():
         time.sleep(0.1)
   def cancel(self):
      Cancels the wireless code transmitter.
if __name__ == "__main__":
   import sys
   import time
   import pigpio
   import _433
   RX=20
   TX=21
   # define optional callback for received codes.
   def rx_callback(code, bits, gap, t0, t1):
      print("code={} bits={} (gap={} t0={} t1={})".
         format(code, bits, gap, t0, t1))
   pi = pigpio.pi() # Connect to local Pi.
   rx=_433.rx(pi, gpio=RX, callback=rx_callback)
   args = len(sys.argv)
   if args > 1:
      # If the script has arguments they are assumed to codes
      # to be transmitted.
      tx=_433.tx(pi, gpio=TX)
      for i in range(args-1):
         print("sending {}".format(sys.argv[i+1]))
         tx.send(int(sys.argv[i+1]))
         time.sleep(1)
      tx.cancel() # Cancel the transmitter.
   time.sleep(60)
   rx.cancel() # Cancel the receiver.
   pi.stop() # Disconnect from local Pi.
The trace shows 8246180 being transmitted on GPIO 21 and being received/decoded on GPIO 20.
mercury:.../common/code$ ./_433.py  8246180
sending 8246180
code=8246180 bits=24 (gap=8995 t0=301 t1=899)
code=8246180 bits=24 (gap=9020 t0=302 t1=897)
code=8246180 bits=24 (gap=9025 t0=303 t1=896)
code=8246180 bits=24 (gap=9025 t0=304 t1=895)
