hamza
can I use rpi as a logic analyzer???
Sun Oct 25, 2015 9:11 pm
hi
buja
Re: can I use rpi as a logic analyzer???
Sun Oct 25, 2015 9:25 pm
hamza
Tue Oct 27, 2015 6:29 pm
Thank u buja
I followed all steps..step by step...but nothing is working...
When I type sudo pigpio
The error is comnand not found...
What is the problem??
Becouse I installed it or rpi 2b
hamza
Tue Oct 27, 2015 6:32 pm
Thank u goode..but I think the rpi is enough to read signal without additional componants.
mahjongg
Tue Oct 27, 2015 6:44 pm
as long as the signals are digital, and stay below 3.3V (or you will blow up the PI which is NOT 5V tolerant).
also, there are very cheap 8-channel USB logic analyzers these day that sell for just $8 or so from Chinese sites, including windows software, they work, I have used them. They are clones of the Salea logic analyzer, but for a tenth of the price, Here is one of them: http://www.dx.com/nl/p/logic-analyzer-w ... i_GRVf4beA
joan
Tue Oct 27, 2015 8:01 pm
hamza wrote:Thank u buja
sudo pigpiod
hamza
Wed Oct 28, 2015 5:11 pm
thank u
I followed all steps,but still not working....plz advice
pi@raspberrypi ~/PIGPIO $ gcc -o foobar foobar.c -lpigpio -lrt -lpthread
gcc: error: foobar.c: No such file or directory
pi@raspberrypi ~/PIGPIO $ sudo ./foobar
sudo: ./foobar: command not found
pi@raspberrypi ~/PIGPIO $ sudo pigpiod
2015-10-28 20:07:01 initInitialise: Can't lock /var/run/pigpio.pid
Can't initialise pigpio library
pi@raspberrypi ~/PIGPIO $ cd
pi@raspberrypi ~ $ sudo pigpiod
2015-10-28 20:07:48 initInitialise: Can't lock /var/run/pigpio.pid
pi@raspberrypi ~ $
hamza
Wed Oct 28, 2015 5:13 pm
mahjongg wrote:as long as the signals are digital, and stay below 3.3V (or you will blow up the PI which is NOT 5V tolerant).
thank you but I quick solution becouse I have no time for sample delevery issue. :D
joan
Wed Oct 28, 2015 10:04 pm
hamza wrote:thank u
pi@raspberrypi ~ $
Try
sudo killall piscope
sudo killall pigpiod
sudo rm /var/run/pigpio.pid
Any of all of the above may return errors. Ignore them.
Then
sudo pigpiod
piscope&
hamza
Thu Oct 29, 2015 6:06 pm
thank you...its working now but the screen is pink...i think there is something wrong!!!@!!!!!
joan
Thu Oct 29, 2015 6:11 pm
I have no idea. Send some events to see if the screen updates.
E.g. from the command line enter the following command
pigs pwm 4 128 mils 1000 pwm 4 0
hamza
Thu Oct 29, 2015 6:24 pm
sorry there is no update or any change..just pink or blue screen. :mrgreen: :?: :roll:
joan
Thu Oct 29, 2015 6:59 pm
hamza wrote:sorry there is no update or any change..just pink or blue screen. :mrgreen: :?: :roll:
I don't know why you have funny colours.
You still don't seem to be starting things properly.
Try
Then
sudo pigpiod
piscope&
(NOT sudo pigpiod & piscope).
hamza
Thu Oct 29, 2015 9:13 pm
Try
Then
sudo pigpiod
piscope&
Thank you but still same problem..... :shock: :roll: :roll:
joan
Thu Oct 29, 2015 9:40 pm
I don't normally run piscope on the Pi.
I just did
wget abyz.co.uk/rpi/pigpio/piscope.tar
tar xvf piscope.tar
cd PISCOPE
make hf
make install
on a Pi2.
It works fine on the Pi2.
hamza
Fri Oct 30, 2015 9:59 am
Thank u joan...its working correctly now
I hope the time mesuearment is accurate.
joan
Fri Oct 30, 2015 11:17 am
hamza wrote:Thank u joan...its working correctly now
The default sampling rate at 5µs intervals should get relative timings accurate to +/- 10µs. That is good enough for almost everything I do on the Pi.
For anything else I'd used a Saleae 8-channel logic analyser dongle clone. They sample at up to 24 MHz.
hamza
Fri Oct 30, 2015 9:04 pm
Thank u ..you are great man.
:D
