williamparry
/dev/lirc0 not appearing on RPi 2
Sat Oct 24, 2015 5:23 am
I've been at this for several hours now and I'm looking to be pointed in the right direction for debugging.
I've been following this tutorial
http://mvartan.com/2014/11/25/controlli ... pberry-pi/
When I go to access /dev/lirc0 it's not there.
Set up
  • Raspberry Pi 2 Model B V1.1
  • Raspbian version 8 (jessie)
  • LIRC installed
Debugging Notes
  • /etc/lirc/hardware.conf is as per tutorial
  • config.txt has
    dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_out_pin=22
    and
    device_tree=
  • /etc/modules has
    snd-bcm2835
    i2c-dev
    lirc_dev
    lirc_rpi gpio_in_pin=23 gpio_out_pin=22
  • When I go
    gpio readall
    it appears that all the modes are set to IN, but I can change pin 22 to OUT manually
  • The IR Blaster differs from the one in the tutorial, it looks like this one
    and I'm ignoring the middle connector
Picture of set up
Here's some of the places I've tried so far to find out what's going on
-rst-
Re: /dev/lirc0 not appearing on RPi 2
Mon Nov 23, 2015 4:17 pm
What is the output if you do these:
sudo /etc/init.d/lirc stop
sudo /etc/init.d/lirc start
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
Mon Nov 23, 2015 4:20 pm
Get rid of the
device_tree=
line because that stops the essential device tree (dtparam) stuff from being loaded.
Batboat
Wed Jan 13, 2016 9:51 pm
Hi William
I have exactly the same problem......did you solve your problem or work around it?
Looking forward to hear from you :)
Cheers Nikolaj
