JaredC79 wrote:I built a custom weather proof box to be used as a camera for my automation systems door station. Is the ribbon connector robust or prone to corrosion? I need to get a longer length and it will be fished thru bricks. Is the ribbon fine or should i get the hdmi cable? I'd image the hdmi is more robust for this application. Any other options to solve this issue?
Are you talking about the camera or screen? There is no HDMI option for the camera.
If you running the camera ribbon through brick than I would cover with heat shrink tubing.
