nerfs
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Fri Jan 11, 2019 12:12 pm
I try to use the following Link, but it doesn't work.
https://www.rmv.de/auskunft/bin/jp/stbo ... 44&start=1
thanks for help
digitalworld
Sat Jan 12, 2019 1:50 am
How can I use remote management on Screenly OSE? I didn't find any document. Is that possible to use on a cloud?
rusko124
Mon Jan 28, 2019 1:01 pm
Stefan_Rasp wrote:
Fri Jan 11, 2019 8:03 am
Thanks for your answer.
I tried to use the same procedure Pi-Gen using the Screenly files.
That's correct?
Or can you kindly explain me the right steps?
Thanks a lot
For example you can:
- Create dir
./stage2/04-new-edits
- Make your new features and edits in file
./stage2/04-new-edits/00-run.sh
- Add packages in file
./stage2/04-new-edits/00-packages
Then try build it
sudo ./build.sh
rusko124
Mon Jan 28, 2019 1:06 pm
Hi, I can suggest to use a balena.io
How to use(Text)
How to use(Video)
rusko124
Mon Jan 28, 2019 1:08 pm
thanks for help
Hi! Could you describe your problem in more detail by creating a issue on github?
SoulBrother1
Sun Feb 10, 2019 9:39 pm
I'm fairly new to the Pi. Currently I have a QuadBoot image running and configured. Running Raspian, RasPlex, Retropi, Kodi.
How would I go about installing Screenly OSE without wiping out my image?Ideally I'd just like to add it to my current setup. Would running an install via the terminal wipe it all out?
nathanstl
Tue Feb 12, 2019 10:03 pm
I have a slide show with 3 urls that cycle 2 mins then 10 seconds and 10 seconds looping. I've been getting one of the urls having a loading error. (site problem I'm assuming) which I would be fine with every once in a while. Problem is screenly stops completely until reboot. It doesn't ever load the next asset so it hangs on the failed url.
PaulR2019
Wed Feb 13, 2019 3:56 pm
I am looking for a way to change the asset location. I'd like to move it from the microSD card to an attached thumb drive. Could some one point me in the right direction?
Thank you for your time.
Paul
rzazula
Used ctrl+alt+F1 to exit Screenly.io OSE. How to restart without reboot
Sun Feb 17, 2019 9:43 pm
Used ctrl+alt+F1 to exit Screenly.io OSE and make configuration changes.
Is there a way to restart Screenly.io OSE without doing a reboot?
The install is Sprint 8 downloaded in Feb 2019, running on a Raspberry Pi 3 B+
