gkreidl
Re: Real Time Transcoding of DVB TV Streams
Thu Jan 04, 2018 3:15 am
gigo1988 wrote:
Thu Jan 04, 2018 1:54 am
Hi Gkreild,
i´ve 2 questions. First do you know how long does the modifikation take from OMX Modul Bug? Second is it possible to put something like a logo to the transcoded stream? Or a feature to do that in the future. I think it must be easy because it will already transcoded but it isnt a must habe feature but nice to have :D
6by9 provided a solution which I have successfully tested in the version I compiled from source. The fix should appear in the Foundation repository within a few days.
Regarding the logo: I have no idea. There might a useful function in one of the gstreamer plugins.
Minimal Kiosk Browser (kweb)
gkreidl
rtranscode 4.0 - Current state of development
Thu Jan 18, 2018 8:12 am
rtranscode 4.0 will run on both Jessie and Stretch (and even on Wheezy, I suppose), but there is a huge difference.
gstreamer-omx-1.0 for the RPI included a lot of patches (30!), which did not only fix bugs but implemented scaling the decoded image using the GPU (Patches 1, 11 and 14). Unfortunately those patches never made it into the upstream gstreamer development and with gstreamer-omx-1.10 software scaling has to be used and this is heavy work for the CPU, especially for HD streams, and limits what can be done. Transcoding will never be as effective on Stretch as it was on Jessie, except if perhaps some good C++ programmer implements HW scaling again.
Otherwise rtranscode 4.0 will contain a lot of new features like deinterlacing, software scalers and support for lots of new video stream resolutions (including such strange formats as 544x576i, which is used on Astra quite a lot) and selection of one of the available audio streams (web interface only).
The newest feature I have added is support for external user scripts for tuning the DVB receiver. Some DVB software or hardware tunes the DVB receiver automatically if you acccess a stream uri (VDR, Tvheadend, Enigma2-Box). Some others require a separate tuning command (Gnutv, mumudvb, HD Homerun systems). User scripts for Gnutv and mumudvb will be part of the package. If you add them to your config file or use a command line option your DVB hardware will be tuned before transcoding starts.
I've also started work on the web interface, which will be included in the package. It is built with the Karrigell framework, which suports user management for different user types. If you connect from your local network, you will have full control: Select a channel, set all stream options, start (optionally including tuning), restart and stop the transcoder. If you connect from the Internet, the server will request user name and password. Depending on the user type it will give limited (only watch or watch and restart transcoder streams) or full control.
Last but not least the package will include two projects, which will let you build your own TV system using either Gnutv or mumudvb. Both projects include a number of scripts, which will create the configuration files, a kweb interface and a channel database and tuning script for rtranscode.
kazuko.nakamura
Re: rtranscode 4.0 - Current state of development
Sat Jan 20, 2018 12:21 pm
Does it means, that old version of rtranscode for Jessie has better performance on RPi2 ???
gkreidl
Sat Jan 20, 2018 1:06 pm
No. The new version has the same performance on Jessie, if you do not use extended features like deinterlacing (which requires software scaling).
kazuko.nakamura
Sat Jan 20, 2018 9:16 pm
Thanks. And also many thanks for your hard work on rtranscode!
mpc823
Tue Jan 23, 2018 7:29 am
Hello Gkreidl,
thank you for making your nice piece of software, I've been waiting so long for.
Just for fun I want to trancode my Sat-DVB-Stream to my sister , to give her the chance to watch BBC. Therefor have been looking for a solution in first step which work with the bandwith of my DSL Internetconnection. Trancoding ist a only solution for this an also I have a little kind of fun playing around.
So now I have read all, but because its not working it looks like I do not understand some important things.
I have downloaded the latest Raspian image from here then I installed rtranscode and before also the pagage for kweb.
I do habe a Linux based Sat Receiver from Coolstream with Neutrino running. On the Webfrontend I could start through a lnk VLC running on my Laptop playing the stream , coming from my SAT-reciever.
The URL looks like "http://192.168.0.203:31339/0,0x13ec,0x0000,0x0000" .This will now playing ARD HD . I try to run HD 264 becouse I do not have the MPEG2 codec for this RP3.
so if I now try to run rtranscode with the URL-> http://192.168.0.203:31339/0,0x13ec there is a error message coming up
[email protected]:~/transcoder/transcoder3 $ rtranscode http://192.168.0.203:31339/0,0x13ec hd1 mpeg 5102
Starting to transcode
Size: 768x432 VBR: 1.76M ABR: 64K AAC
Listening on http://127.0.0.1:9080/xyz.mkv
Starting pipeline
Warning Delayed linking failed.
Error Internal data stream error.
Or because of aac ???? I tried
[email protected]:~/transcoder/transcoder3 $ rtranscode http://192.168.0.203:31339/0,0x13ec hd1 aac 5102
Starting pipeline
the information output of omxplayer show me :
[email protected]:~/transcoder/transcoder3 $ omxplayer -i http://192.168.0.203:31339/0,5101
[h264 @ 0x1345c30] SPS unavailable in decode_picture_timing
[h264 @ 0x1345c30] non-existing PPS 0 referenced
[h264 @ 0x1345c30] decode_slice_header error
[h264 @ 0x1345c30] no frame!
Input #0, mpegts, from 'http://192.168.0.203:31339/0,5101':
Duration: N/A, start: 88632.291211, bitrate: N/A
Program 1000
Stream #0:0[0x13ed]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(progressive), 1280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0:1[0x13ee](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 256 kb/s
Stream #0:2[0x13ef](mis): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 256 kb/s
Stream #0:3[0x13f2](deu): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 448 kb/s
Stream #0:4[0x13f1](deu): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
Stream #0:5[0x13f0](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
have a nice day ;)
So I do not have a nice day :-D but could it be that the stream from my DVB-reciever is incompatible for rtranscode. ?
Find out whats going on I thought it might be a good idea to try to get a stream from a SAT-IP-Server. Therefore I grabed some time a go a nice piece of hardware from Digital-Device . The "Octupus Net" could make DVBS DVBS2 DVBC DVBT DVBT2 available in the network. But there is only the way pick up the stream through rtsp., but rtranscode need the http stream.
Working with the rtsp call all the information for zapping channels (freq pid diseqe ...... ) and then tuning to the channel is inside the rtsp request which is not supported by rtranscode .
So I want to ask please could you give me a hint why rtranscode did not work with my SAT receiver ?
and is the a chance to make rtranscode compatible for the SAT-IP protokoll ?
many thanks Martin
gkreidl
Tue Jan 23, 2018 12:09 pm
1. The current version of rtranscode doesn't run on Raspbian Stretch. rtranscode 4.0 is in development (and beta testing) and will replace it in a few weeks. It will run on both Jessie and Stretch.
2. rtranscode does support http and udp streams, but no rtsp (but this may change in the future).
You seem to be running Stretch, so please have some patience. The 4.0 version should be ready for publication some time in February.
mpc823
Tue Jan 23, 2018 7:11 pm
Hello Gkreidl,
Thank you very much for your hint . :D Now it's working on Jessie.
It makes me a lot of fun playing with your transcoding software.
Bastinazo
Fri Feb 23, 2018 3:02 am
Any good new about v4 ???? :D
gkreidl
Fri Feb 23, 2018 5:39 am
I had to stop working on it for two weeks, but yes: the new manual (about 70 pages) is ready except for one chapter and proof reading. I'm still working on the web interface, but everything else is almost ready for publication. I'm looking forward to publish it some time in March.
Bastinazo
Sat Feb 24, 2018 1:50 pm
Great !
Very impatient :mrgreen:
gkreidl
Thu Mar 29, 2018 9:04 am
The work on rtranscode 4.0 has been finished yesterday. I'll send the final version to my beta testers today and it should be ready for download within the next few days.
The new manual is already available online.
The image below shows the web interface.
kazuko.nakamura
Sat Mar 31, 2018 10:11 am
Great job! Thank You for your hard work.
Is this interface is working with previous version rtranscode?
gkreidl
Sat Mar 31, 2018 10:42 am
I an way, yes. The web server contains its own transcode module based on rtranscode V. 4. It's able to work stand-alone. Although the format of channel databases has changed a bit, both the web server module and rtranscode V. 4 can still read the old database format.
jccj78
Sat Mar 31, 2018 10:49 am
Awesome interface , thank very much for your great job.
I have two questions:
1- Can I use tvheadend like a backend (tunner backend) ?
2- How playing transcoding? Directly with nice interface ? What player, Kodi, Vlc?
Thank alots for your time!
gkreidl
Sat Mar 31, 2018 10:53 am
I cannot test tvheadend, but a user has got it to work in the past.
To watch the stream you can use almost any player on any computer platform which can access live http streams. On the RPi I have tested it with omxplayer(GUI), VLC with HW acceleration and kodi.
jccj78
Sat Mar 31, 2018 10:58 am
Then I can only watch free to air channels without tvheadend, I guess.
gkreidl
Sat Mar 31, 2018 11:56 am
I didn't say that it doesn't work with tvheadend, I just cannot test it. But if someone got the old version to work with tvheadend (you will find it in this thread), it should also work with the new version. Unfortunately none of my beta testers is using tvheadend.
And there's also another solution. The new package includes tools to set up a mumudvb backend which supports CAMs and softcams (oscam).
Bastinazo
Sat Mar 31, 2018 6:58 pm
I can not wait to try it :D
gkreidl
Tue Apr 03, 2018 8:12 am
rtranscode V 4.0 is now available. For details and download instructions check the second posting of this thread.
Bastinazo
Tue Apr 03, 2018 4:33 pm
gkreidl wrote: rtranscode V 4.0 is now available. For details and download instructions check the second posting of this thread.
Thanks you gkreidl !!
jccj78
Tue Apr 03, 2018 6:43 pm
Thanks from my heart gkreidl!
jccj78
Fri Apr 06, 2018 9:39 pm
I am following the pdf tutorial. I get error on that lines:
For MuMuDVB:
The MuMuDVB package from the repository is very old and should not be used. I
build new packages for the Raspberry Pi from time to time which are available from
the MuMuDVB website: http://mumudvb.net/download/
Download the latest release and install it with gdebi (to get all dependencies):
sudo apt-get install gdebi-core
sudo gdebi -y file-name
where file-name is the name of the package which you have downloaded.
-----> sudo gdebi -y file-name ----> error on parameter -y
I try without -y and seems to work:
sudo gdebi mumudvb_2.1.0-3-b3c9ae7_armhf.deb
Reading package lists... Done
Building dependency tree
Requiere la instalación de los siguientes paquetes: libdvbcsa1
multicasts all channels of a DVB transponder on a network
¿Quiere instalar el paquete de software? [s/N]:s
Get:1 http://ftp.cica.es/mirrors/Linux/raspbian/raspbian stretch/main armhf libdvbcsa1 armhf 1.1.0-2 [54.4 kB]
Fetched 54.4 kB in 0s (0 B/s)
Seleccionando el paquete libdvbcsa1:armhf previamente no seleccionado.
(Leyendo la base de datos ... 150879 ficheros o directorios instalados actualmente.)
Preparando para desempaquetar .../libdvbcsa1_1.1.0-2_armhf.deb ...
Desempaquetando libdvbcsa1:armhf (1.1.0-2) ...
Configurando libdvbcsa1:armhf (1.1.0-2) ...
Seleccionando el paquete mumudvb previamente no seleccionado.
(Leyendo la base de datos ... 150886 ficheros o directorios instalados actualmente.)
Preparando para desempaquetar mumudvb_2.1.0-3-b3c9ae7_armhf.deb ...
Desempaquetando mumudvb (2.1.0-3-b3c9ae7) ...
Configurando mumudvb (2.1.0-3-b3c9ae7) ...
Is correct my mumudvb installation?
gkreidl
Sat Apr 07, 2018 3:11 am
For MuMuDVB:
Yes, but I have provided a newer version with this package. From the rtranscod4 directory run
sudo ./install_mumudvb
BTW, it was a typo in the manual (must be -n ). I have fixed it now.
jccj78
Sat Apr 07, 2018 9:47 pm
I am getting error when I generate channels.dat :
[email protected]:~ $ rtranscode -i=playlist.m3u -o=channels.dat
analyzing: http://192.168.1.215:9981/stream/channelid/2062929554
analyzing: http://192.168.1.215:9981/stream/channelid/582454247
File "/home/pi/transcoder4-dev/sources/rtranscode.py", line 1580, in <module>
File "/home/pi/transcoder4-dev/sources/rtranscode.py", line 1406, in create_channelsdb
NameError: global name 'amode' is not defined
My playlist.m3u is from tvheadend:
http://192.168.1.215:9981/stream/channelid/2096827154
http://192.168.1.215:9981/stream/channelid/2079525138
http://192.168.1.215:9981/stream/channelid/93499316
What is the problem? Thank!
