bookedirl
Auto mount network drive Issue - Jessie
Sun Oct 18, 2015 3:06 pm
I'm having some trouble with mounting my network drive on boot. I did a fresh install of jessie and this was the first thing I tried doing. Once I reboot I can see my usb drive being mounted then after that when it says:
Oct 18 03:40:41 raspberrypi systemd[1]: Starting ifup for eth0...
Oct 18 03:40:41 raspberrypi systemd[1]: Started ifup for eth0.
Oct 18 03:40:41 raspberrypi systemd[1]: Starting Network.
Oct 18 03:40:41 raspberrypi systemd[1]: Reached target Network.
Oct 18 03:40:41 raspberrypi systemd[1]: Starting Network is Online.
Oct 18 03:40:41 raspberrypi ifup[418]: /sbin/ifup: interface eth0 already configured
Oct 18 03:40:41 raspberrypi systemd[1]: Reached target Network is Online.
Oct 18 03:40:41 raspberrypi systemd[1]: Mounting /mnt/media...
Oct 18 03:40:41 raspberrypi mount[420]: mount error(101): Network is unreachable
Oct 18 03:40:41 raspberrypi mount[420]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Oct 18 03:40:41 raspberrypi systemd[1]: mnt-media.mount mount process exited, code=exited status=32
Oct 18 03:40:41 raspberrypi systemd[1]: Failed to mount /mnt/media.
Oct 18 03:40:41 raspberrypi systemd[1]: Dependency failed for Remote File Systems.
Oct 18 03:40:41 raspberrypi systemd[1]: Unit mnt-media.mount entered failed state.
Here's my fstab (<name> and <pass> contain correct name and pass)
//192.168.1.38/Media /mnt/media cifs username=<name>,password=<pass>,uid=1000,gid=1000,_netdev 0 0
If I do a mount -a when logged in it works so I'm not sure whats going on here. Anyone have any ideas?
KLL
Re: Auto mount network drive Issue - Jessie
Mon Oct 19, 2015 5:43 am
it means that also with JESSIE the "cifs" mount problem is still not solved.
as work around you could put the command line
sudo mount -a in a login startup ..
i try to keep all that settings together in one file like in nano .bash_aliases
if you search the forum you will find many remarks not use "cifs", better NFS
Mon Oct 19, 2015 7:43 am
bookedirl wrote: //192.168.1.38/Media /mnt/media cifs username=<name>,password=<pass>,uid=1000,gid=1000,_netdev 0 0
... Anyone have any ideas?
Add
,x-systemd.automount
after
_netdev
bookedirl
Mon Oct 19, 2015 7:26 pm
DougieLawson wrote:
bookedirl wrote:
Add
after
_netdev
I tried this but it did not work for cifs apparently
mount error(22): Invalid argument
JimmyN
Mon Oct 19, 2015 7:54 pm
It works for cifs. I use it to mount a share on a FreeNAS box. When I upgraded to Jessie it no longer mounted at boot, but now it's ready before I am. You must have a typo somewhere in the line, or something out of place. Here is the line I'm using in fstab
//192.168.0.98/NetworkFolder /home/jimmy/network-folder cifs credentials=/home/jimmy/.smbcredentials,uid=jimmy,gid=jimmy,_netdev,x-systemd.automount 0 0
bookedirl
Mon Oct 19, 2015 8:10 pm
Ok, I apologize I have 2 pis/puttys open one has wheezy other has jessie.. when I call this code it doesn't throw any errors. However, when I reboot the pi and see if it mounts properly it gives the same error as in post 1.
//192.168.1.38/Media /mnt/media cifs username=name,password=pass,uid=1000,gid=1000,_netdev,x-systemd.automount 0 0
I feel like this should just work with the _netdev option based on what I read up on it.. I don't want to do a work-a-round if I don't need to but I guess I will if I can't figure out what's causing not to mount on boot. Could any other settings be effecting this?
kaosrq
Wed Nov 18, 2015 3:37 am
in my case, solve it by editing the network interface, to automatically start with dhcp,
edit:
sudo nano /etc/network/interfaces
add as applicable:
auto eth0
iface eth0 net dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
Gedarius
Sun Jul 10, 2016 9:28 pm
sorry to late reply, but i had the same problem and this is how i solve it:
first give permission to your mount point:
sudo chown -R pi:pi /mnt/HD1
sudo chmod -R 775 /mnt/HD1
sudo setfacl -Rdm g:pi:rwx /mnt/HD1
sudo setfacl -Rm g:pi:rwx /mnt/HD1
then, write the line below in the fstab:
//192.168.0.111/myNetworkFolder     /mnt/HD1   cifs username=MyUsr,password=MyPass,sec=ntlm,uid=pi,gid=pi,_netdev,xsystemd.automount 0 0
username and password parameters are credentials of you network drive, in my case, its a FTP from my router (a USB pendrive)
pay attention on the sec=ntlm parameter, this make all the difference for me
this is it, reboot your raspberry and see it works =]
CraziFuzzy
Tue Aug 02, 2016 7:06 am
Gedarius wrote:Hello,
xsystemd.automount causes the mount to choke with an Invalid argument - it won't even work with a 'sudo mount -a'. removing it and at least sudo mount -a works.
JimmyN
Wed Aug 03, 2016 9:46 am
That's probably because it should be "x-systemd.automount", rather than "xsystemd.automount".
