f6bvp
HamRadio AX.25 packet on RaspBerry
Tue Jul 24, 2012 8:53 pm
I succeeded the compilation of a dedicated Raspbian 3.1.9+ kernel with packet radio modules (6pack, kiss, Rose, NetRom).
I followed instructions given in Debian paragraph of http://elinux.org/RPi_Kernel_Compilation
I then installed a ROSE node switch FPAC on my RPi.
Node will soon be available through ssh.
Compilation took the whole night but it did not hurt as I was sleeping !
Now I will install a co located F6FBB BBS.
At the same time lighttpd is running a web page advertizing RPi at
http://f6bvp.org:8080
I need some help to build a deb package including kernel binary image and AX.25 modules in order to help other hams interested by this project.
73 de Bernard, f6bvp
another_mikey
Re: HamRadio AX.25 packet on RaspBerry
Tue Jul 31, 2012 12:15 am
I am looking to try hosting a DXCluster using the Pi and am very interested in what you might have found out regarding the process for adding many of the modules and recompiling. I will need the Ax25 support for sure - not sure about the ROSE stuff though - I don't think I have any need of that.
Only other concern will be for getting a RS-232 port working. I will likely try a USB to serial adapter as a simple solution and then go towards using one of the dedicated serial ports (with level conversion) if I need to.
Anyway, wanted to post to find out if you were going to make any builds of the kernel available with AX25 installed or if you had any other advice before I embark on trying to rebuild it myself.
is there a way to do it with a cross compiler under Windows & as I am assuming the long duration must have meant you compiled things natively on the Pi itself?
ML/KE0MF
g8bpq
Sat Aug 04, 2012 8:11 am
The bootc kernels include all the ax.25 modules, so i suggest you use them rather than building your own kernel. There is a build for raspian posted somewhere on the site.
I have a node working, running NETROM over the Ethernet port using the BPQEther driver, and KISS using the serial port. You have to stop the system using the port, both for kernel messages and a getty.
I have just about completed a TNC that will plug into the expansion header. The prototype is a modified TNC-X, but I hope to produce a customised board. The idea is to talk to the PI over i2c, so more than one TNC can be connected (it will have a stackable header)..
73, John G8BPQ
k4gbb
Fri Sep 14, 2012 6:42 pm
I have set up two Raspberries. Both running FPAC (ROSE) and Net Rom.
Both are supporting a RMS Gate. We are having some trouble setting up the VA site to run with a TNC-X. The FTDI drivers appear to be problematic.
You can find a script to install ax25 on the Raspberrian Wheezy image dated 8/16/2012.
on my Raspberry RMS Gate web site[url]html://k4gbb.no-ip.info/docs/Raspberry.html[/url].
The secret seems to be finding a solid PSU and USB hub.
73
<<Charley>>
k4gbb
The Grass may be greener on the other side of the fence, but it still has to be mowed.
k4gbb
Sun Sep 16, 2012 10:20 pm
Recent modifications of the FTDI driver used the TNC-X have resulted in a stable working environment.
The original FTDI USB driver would nether send or receive. The updated driver from FTDI's web site was installed and the USB port was operational. Our choice of HUBs was unfortunate. There was a problem connecting the TNC thru the USB3 hub. It had an issue regarding communicating to the the RPi the connection of USB2 devices. Therefore the TNC-X was never recognized.
Connecting the TNC directly to the RPI was the only way to make it work. Later, a borrowed HUB was substituted and allowed the TNC to be powered externally.
While this updated USB driver made the Ax.25 port work it made the RPi somewhat unstable. It would run for hours and lock-up. The 8000 interrupts thread http://www.raspberrypi.org/phpBB3/viewt ... 20#p156720 shows more work being done on the FTDI USB driver. The work by gsh seems to have solved the problem.
You will find instructions and documentation for installing a TNC-X using the USB interface at http://k4gbb.no-ip.info/docs/Raspberry.html
73
<<Charley>>
k4gbb
abqden
Sat Apr 18, 2015 12:10 am
I'm trying to learn more about networking and AX25, so I've recently pressed a Raspberry Pi into service and am having a lot of fun getting my education. I've run into a curious thing, though, that has me stumped. To start with, I set up two vhf stations in the same room using 30-year-old legacy tnc's.
I could originate a connection from either tnc with the other and chat back and forth. Then I replaced one of the legacy tnc's with a Raspberry Pi and a "Pi-Tnc" and linux AX25. I can still originate a connection from the other tnc, and the other tnc reports it successfully connected. It gives me a split screen to chat with. But my AX25 machine just sits there at the prompt. I can look at the raw data and see the AX25 machine sends out packets indicating that it also thinks it successfully connected.
At this point I'm just to new to the complexities of AX25 to troubleshoot effectively. Is anyone familiar enough with the Raspberry Pi version of AX25 to know how I get it to open a chat console window? I loaded AX25 on the Raspberry Pi using the handy "Instax25.new" script provided by Charles Schuman (K4GBB), and when I ran into this problem I tried the pre-built image "RPi-3.12.22.AX.25-July-1.img" put together by F6BVP.
When F6BVP's image did the same thing it made me realize I probably have a configuration issue, and I can put all the AX25 images I want on the Rpi and it won't solve the problem because the real problem isn't the software. The real problem is that I don't know what I'm doing!
So to sum up, regardless of which AX25 image I use, I can use the "call" program to make outbound connections, but inbound connections are not displayed even though the Rpi is actively participating in the connection. I have a feeling the solution is a simple matter of matching up the right items in the right configuration files, but right now I haven't a clue.
Dennis ki5ik
g8bpq
Sat Apr 18, 2015 7:25 am
Dennis,
With the Linux Kernal ax.25 an incoming call has to be routed to an application using ax25d (configured with ax25d.conf). This tells the system what program to run when a call arrives. There are lots of packet applications, but I'n not aware of a simple terminal that can be used for terminal-to-terminal chat.
LinBPQ is an alternative to the Kernal ax.25 stack. It is a fairly complex node package, but I've produced a guide to configure it as a simple packet terminal for the TNC-PI. See
https://sites.google.com/site/bpq32wiki ... s-terminal
for details. Note if you use this, you shouldn't run kissattach or axlisten.
73, John G8BPQ
abqden
Sun Apr 19, 2015 5:06 pm
John, G8BPQ
Thank you very much for taking the time to make a speedy reply and straighten me out, John. Looking at the posting dates on this topic, I expected no reply, or at best something in a few weeks. Now that I have a better idea of the big picture, I can see my thinking was still geared to the early days of packet radio, so you've saved me a great deal of time getting on board. When I saw your call sign I thought "that looks familiar" and Googled you on the web. Wow, you've been a power house of progress and ideas, so I'm honoured to have a reply from an important Guru. I believe all that good energy will be returned to you multiplied. I joined the BPQ32 group and look forward all the fun.
Dennis
ki5ik
k4gbb
Tue Apr 28, 2015 6:39 pm
Within the ax25 tools there is a terminal utility called ax25call.... or maybe just call.
It is a basic terminal pgm that will work for most ax.25 purposes.
The basic command is Call <port>
See the man page for other options.
Sorry.y I am a bit late replying to your post my laptop Hd Crashed and I am just getting things restored.
73
<<Charley>>
k4gbb1@gmail.com
abqden
Sat May 02, 2015 5:05 pm
Hi Charley,
Thank you so much for taking the time to shoot me a line. I know how busy you must be, so I appreciate it. Things are making a lot more sense now, thanks to people such as yourself who take the time to educate us newcomers. I frequently see your call when I am searching these forums for information, so I'm honoured you replied. When I was a kid my Aunt used to tell me, "If you want something done ask the busy, because the others don't have time".
73's
Dennis, ki5ik
k4gbb
Sat May 02, 2015 5:49 pm
Actually Dennis...
I am one of those people that has nothing better to do other than Help those who are New in AR or computing.
I am retired and have been a HAM since 1957. I'm doing what they call "Paying it Forward." Many people helped
me when I was a Newbee and this is my way to say THANK YOU.
Besides that it keeps me out of the bars and brothels! :lol:
<<Charley>>
k4gbb
f6bvp
New SD image upgraded AX25 RaspBian
Sat Feb 20, 2016 10:28 pm
I have just published a new micro SD image of AX.25 preconfigured Raspbian Wheezy entirely upgraded.
Last release was dated July 2014 !
A total of 117 packages have been updated including RaspBerry Pi firmware, Linux kernel libraries and RaspBian kernel.
All included AX.25 application are up-to-date.
Firmware and kernel 4.1.17 #843 Mon Feb 15 GMT 2016 ;
xastir 2.0.7;
Ve7fet libax25 ;
FPAC 4.0.3;
LinFBB 7.0.8;
There are two available images :
One is a tar.bz2 archive that can be uncompressed under Windows by 7-zip or WinRar (http://www.win-rar.com):
RPi_AX.25_4.1.17.img.tar.bz2
Second image can be uncompressed using new Linux utility unxz : RPi_AX.25_4.1.17.img.xz
See links on site http://f6bvp.org/AX25_BBS_Node_RaspBerr ... stall.html
Time of file transfer is highly dependant on your Internet connection speed.
However, even with optical fiber connexion, estimated download was 4-5 hours on first trial and then 6 minutes (!!!!) on a second trial. This shows that Free repository may also have some kind of speed variations.
Who is online
Users browsing this forum: Bing [Bot], pcmanbob and 14 guests
